Electrical Specifications:
Series
Model
Step
Angle
Motor
Length
(mm)
Rated
Current
(A)
Phase
Resistance
(Ω)
Phase
Inductance
(mH)
Holding
Torque
(N.cm Min)
Detent
Torque
(N.cm Max)
Rotor
Inertia
(g.cm²)
Lead
Wire
(No.)
Motor
Weight
(g)
8HS2402
1.8
28
0.2
23
8.2
1.4
0.2
2.5
4
8HS2406
1.8
28
0.6
3.2
0.9
1.4
0.2
2.5
4
8HS3402
1.8
34
0.2
25
8.4
1.8
0.3
3.2
4
70
8HS3406
1.8
34
0.6
4.5
1.2
1.8
0.3
3.2
4
70
8HS4402
1.8
40
0.2
32
8.8
2.6
0.5
4.5
4
82
8HS4406
1.8
40
0.6
5.8
1.6
2.6
0.5
4.5
4
82
