Electrical Specifications:
Model
Step distance
mm/step
Motor Length
L(mm)
Rate
Voltage
(V)
Rate Current
(A)
Phase Resistance
(Ω)
Phase Inductance
(mH)
Holding Torque
(N.m)
Lead Wire
(NO.)
Detent
Torque
(kg.cm)
Rotor
Inertia
(kg.cm )
Motor Weight
(kg)
57BYGHL013
0.04
41
2.7
1.5
1.8
4
0.4
4
0.21
0.12
0.45
57BYGHL216
0.04
51
3.3
1.7
1.95
6
1
4
0.36
0.275
0.65
57BYGHL401
0.04
56
6
0.6
10
32
0.9
4
0.4
0.3
0.7
57BYGHL602
0.04
78
10.4
0.8
13
42
1.98
4
0.68
0.48
1
