K33Aº«¹úÈÕйâÏËÈÛ½Ó»ú²úÆ·ÌØµã
ÍøÂçÔ¶³Ìά»¤,·ÀÕ𣬷À³¾£¬·ÀË®
¶à¹¦Äܼ¯³É£¬Ìṩ¸üºÃʹÓÃÌåÑé
5´ó¹¦Äܼ¯ÎªÒ»Ì壨°þÏË¡¢Çå½à¡¢ÇиÈÛ½Ó¡¢ÈÈËõ£©
ʹÓÃ×Ô¶¯ÈȰþǯÎ޹κۣ¨¹âÏË¿¹ÀÇ¿¶ÈÔö´óµ½£¾3kgF£©
5Ó¢´ç²ÊÉ«LCD´¥ÆÁ£¬´¥ÆÁ°´¼üºÍË«Ïò²Ù×÷ϵͳ
´óÈÝÁ¿ï®µç³Ø6000mAH
ÇиƬÊÙÃü¿É´ïµ½75000о
K33Aº«¹úÈÕйâÏËÈÛ½Ó»ú¼¼ÊõÖ¸±ê
Ãû³Æ
ÃèÊö
¹âÏ˶Ô×¼
IPAASÏËо¶Ô×¼
ÊÊÓùâÏËÀàÐÍ
SM(G.652),MM(G.651),DS(G.653),NZDS(G.655),SM(G.657A2/B2),SM(G.657B3)
¹âÏËÊýÁ¿
µ¥Ð¾
ÊÊÓùâÏËÖ±¾¶
°ü²ãÖ±¾¶£º80-150um,Í¿¸²²ãÖ±¾¶£º100umTmm
Çи¶È
250um:8mm-16mm,900um:16mm(ʹÓüоߣº8mm)
¹¤×÷ģʽ
ÈÛ½Óģʽ£º100,¼ÓÈÈģʽ£º50
µäÐÍÈÛ½ÓËðºÄ
SMF:0.02dB, MMF:0.01dB, DSF:0.04dB, NZDS:0.04dB
»Ø²¨ËðºÄ
>60dB
ÈÛ½Óʱ¼ä
µäÐÍ9Ãë
Ô¤¹ÀËðºÄ
ÊÊÓÃ
ÈÈËõʱ¼ä
9Ã루IS-45Ì׹ܣ¬IS-45ģʽ£©£¬13Ã루IS-60Ì׹ܣ¬IS-60ģʽ£©
ÊÊÓÃÌ×¹ÜÀàÐÍ
32mm, 40mm, 60mm/28mm»ò32mm(Á¬½ÓÆ÷)
ÈÛ½Ó½á¹û´æ´¢
Êý¾Ý£º10000,ͼÏñ£º10000
ÀÁ¦²âÊÔ
2N/4.4N (¿ÉÑ¡)
¹¤×÷»·¾³
º£°Î£º0~5000mζȣº-10°C~50°C£¬Êª¶È£º0~95%·çËÙ:15m/s,ÎÞ½á˪£¬·À³¾£¬·ÀË®£¬·ÀÕð
´æ´¢»·¾³
ζȣº-40°C~80°C,ʪ¶È£º0-95%
³ß´ç
142 (W) x219 (L) x137 ( H)mm (º¬Ï𽺻¤Ì×)
ÖØÁ¿
2.45kg£¨º¬µç³Ø£©
¹âÏ˹۲ìºÍÏÔʾ
Á½¸öCMO SÉãÏñ»úºÍ5Ó¢´ç²ÊÉ«LCDÏÔʾÆ÷£¨¾²µç´¥ÃþÆÁ£©
¹âÏË·Å´ó±¶Êý
X/Y200X,×î´ó400X
µçÔ´¹©µç
100-240V
µç³ØÈÝÁ¿
µäÐÍ230´Î(6000mAh)
µç¼«ÊÙÃü
N10000´Î
Íâ½Ó¶Ë¿Ú
USB,Íâ½ÓµçÔ´£¨DV 12VÊÊÓÃÓÚÆû³µµãÑÌÆ÷£©
ÇиÐͺÅ
CF-07FT
µ¶Æ¬ÊÙÃü£¨µ¶Æ¬ÊÙÃü»áÊܹ¤×÷»·¾³Ó°Ï죩 75000´Î
K33Aº«¹úÈÕйâÏËÈÛ½Ó»ú±ê×¼ÅäÖÃ
Ãû³Æ
ÐͺÅ
ÊýÁ¿
¹âÏËÈÛ½Ó»ú
K33A
1
ʹÓÃÊÖ²áCD
1
±¸Óõ缫
EI-23
1
ÀäÈ´¼Ü
Ò»
1
Я´øÏä
Ó²Ïä
1
ï®µç³Ø
6000mAh
1
½»Á÷ÊÊÅäÆ÷
1
¹¤¾ßÏä
1
K33Aº«¹úÈÕйâÏËÈÛ½Ó»úÑ¡¼þ
K33A¹âÏËÈÛ½Ó»úÃû³Æ
ÐͺÅ
ï®µç³Ø
6000mAh
ÇиƬ
BI-07
µç¼«°ô
EI-23
µçÔ´
DC 12VÊÊÓÃÓÚÆû³µµãÑÌÆ÷
ÈÈËõ¹Ü
S-160 (60mm) ,S-140(40mm)
Ì׹ܼÐ
Ò»
¹âÏ˼оß
HS-250, HS-900, HS-2.5F,HS-IN,HS-SC/FC,
HS-ILC,HS-ST,LS-900 (ËÉÌ×¹Ü),
SCOÁ¬½ÓÆ÷
SC,LC,FC,ST
Çи
CF-07FT
¹âÄ£¿é
¹â¹¦Ä£¿é£¨¹â¹¦ÂʼƺͿÉÊÓ¹ÊÕÏ̽²âÒÇ£©
