产品名称: 博控 网络模块WIZ812MJ
型  号: WIZ812MJ
价  格:
 特征
- 插针式模块化设计
- 集成W5100、滤波器、RJ45
- 基于多种MCU的快速评估版
- 支持4个Socket同时连接
- 支持8位数据总线和串行SPI
- 10/100Mbps自适应以太网接口
- 支持网络状态指示灯
- 尺寸:55.2 x 25 x 22.5 mm
规格(WIZ810MJ vs. WIZ811MJ vs. WIZ812MJ)
  WIZ810MJ WIZ811MJ WIZ812MJ
Architecture TCP/IP W5100
PHY Embedded in W5100
Mag Jack RDA-125BAG1A
Interface 10/100 Base-T Ethernet (Auto Detection)
Network Protocol TCP, UDP, IP, ARP, ICMP, IGMP, PPPoE, MAC
Dimension(mm) 52 x 25 x 21
(W x H x D)
55.5 x 25 x 23.5
(W x H x D)
55.5 x 25 x 23.5
(W x H x D)
Connector Type
2mm pitch
14 x 2 header
2.54mm pitch
10 x 2 header
2.54mm pitch
10 x 2 header
J2:9 GND
->RX_LED
J2:10 GND
->TX_LED
J2:19 GND
->LINK_LED
PCB Through Hole X
Two PCB Throughhole
(ø3.00mm)
Four PCB Throughhole
(ø3.00mm)
SPI Signal Pin Shared for SPI
and BUS signals
Separated for
SPI signals
(SPI_EN controlled by /SCS signal)
Separated for
SPI signals
LINK LED When the link is established,
LED is on and flashes at the TX or RX
LED is on,
but not flashes
at the TX or RX
Input Voltage 3.3V internal operation and 5V tolerant I/Os
Power Consumtion 10/100 baseT max. 185mA (3.3V)
 订货信息
Model Description
WIZ812MJ Network Module with Mag Jack (Transformer and RJ45)
关 键 词: WIZ812MJ 网络模块 WIZnet
公司名称: 北京博讯科技有限公司
联 系 人: 吕锐
电  话: 010-51663110
手  机: 15810553937
地  址: 北京市海淀区中关村南大街6甲铸诚大厦
邮  编: 100086
博讯 ZigBee芯片J(JN5121)
工业级网络模块(WIZ8(WIZ850SW)
博控 应用开发包WIZ-(WIZ-Embedded webserver)
RS232转ZigBee(GW410)
博控 应用开发包WIZ-(WIZ-iStorage)
Jennic的JN513(JN5139-Z01-M04)
JN5121-Z01-M(JN5121-Z01-M02)
JN5148无线微控制器(JN5148)
Jennic2.4G芯片(JN5139)
RS485转ZigBee(GW420)
即插即用网关模块(WIZ(WIZ120SR)
2.4G无线模块JN51(JN5121-Z01-M00)
WiFi转ZigBee设(GW430)
802.15.4模块JN(JN5121-Z01-M01)
2.4G无线模块JN51(JN5139-Z01-M03)
AX11015单芯片以太(AX11015)
博控 评估板W5300E(W5300E01-ARM)
博控 应用开发包WIZ-(WIZ-iRadio)
W7100四合一(TCP(W7100)
博控 网络模块WIZ11(WIZ110SR)
