产品介绍: |
特征 |
- 以太网到WiFi的桥梁 - 最大速率可达25Mbps - 支持802.11b/g无线通讯标准 - 支持AP、AP Client、串口转WiFi等模式 - 支持64/128位WEP、WPA、WPA2(AES)等加密协议 - 支持MII、UART、GPIO、UFL天线连接器等接口 - 尺寸:39mm x 32mm x 4.7mm - 兼容RoHS
规格 |
| ■ Wireless Specifications ■ |
| Wireless Standards |
IEEE 802.11b; 802.11g |
| Frequency Range |
2.412GHz ~ 2.462GHz (US & Canada) |
| 2.412GHz ~ 2.472GHz (Europe) |
| 2.412GHz ~ 2.484GHz (Japan) |
| Output Power |
14dBm@802.11b(1~11Mbps) 14dBm@802.11g(1~54Mbps) |
| Receive Sensitivity |
802.11b -65dBm@11Mbps 802.11g -76dBm@54Mbps |
Data Rates With Automatic Fallback |
54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps, automatically fallback to 5.5Mbps, 2Mbps, 1Mbps |
| 11Mbps, 5.5Mbps, 2Mbps, 1Mbps |
| Range |
Up to 200m/2dBi antenna gain |
| Modulation Techniques |
OFDM, CCK |
| ■ Serial Interface ■ |
| Interface |
UART CMOS (Asynchronous) 3.3V-level signals, rate is software selectable |
| Serial Line Formats |
7 or 8 data bits, 1-2 Stop bits |
| Parity |
odd, even, none |
| Flow Control |
XON/XOFF (software), CTS/RTS (hardware), none |
| ■ Network Interface ■ |
| Interface |
MII, Wireless 802.11b, 802.11g |
| Protocols Supported |
TCP, Telnet, DHCP, HTTP, SMTP, TFTP |
| ■ Management ■ |
| HTTP / Telnet |
| ■ Security ■ |
| WEP 64/128bit, WPA/WPA2 PSK/AES/TKIP, 802.1x(Radius) |
| ■ Power Consumption ■ |
| Average Consumption |
3.3V summary(W) 10Mbps HD(Traffic) 0.27A 0.42 100Mbps HD(Traffic) 0.119A 0.39 |
| ■ Environmental ■ |
| Operating range,WLAN |
0~55°C |
| Storage range |
-20~ 77°C |
订货信息 |
| Model |
Description |
| WIZ610wi |
802.11b/g Wireless Module |
| WIZ610wi-EVB |
Evaluation Board for WIZ610wi | |
