Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÑлªÄ£¿é,Ñлª·Ö²¼Ê½I/O,Ä£ÄâÁ¿Êä³öÄ£¿é
²úÆ·Ãû³Æ£º ÑлªÄ£¿é,Ñлª·Ö²¼Ê½I/O,Ä£ÄâÁ¿Êä³öÄ£¿é
ÐÍ ºÅ£º ADAM-5024 4·ģÄâÁ¿Êä³öÄ£¿é
Æ· ÅÆ£º 32
ADAM5000ϵÁÐÄ£¿é
²úÆ·Ö÷ÒªÌØÐÔ:
ͨµÀ£º4·
ÓÐЧ·Ö±æÂÊ£º12λ
Êä³ö·¶Î§£º¸ôÀëµçѹ
Êä³öÀàÐÍ£ºmV, V
¸ôÀëµçѹ£º3000 VDC
²ÉÑùËÙÂÊ£º10²ÉÑùµã/Ãë
¾«È·¶È£ºÂúÁ¿³ÌµÄ¡À0.1%
·Ö±æÂÊ£ºÂúÁ¿³ÌµÄ¡À0.015%
ÄÚÈݽéÉÜ
The ADAM-5024 is a 4-channel analog output module. It receives the digital input from the ADAM-5000 system or the host computer on RS-485 network. The format of the data is engineering units. It then uses the D/A converter controlled by the system module to convert the digital data into output signals. You can specify slew rates and start up currents through the configuration software. The analog output can also be configured as current or voltage through the software utility. The module protects your equipment from ground loops and power surges by providing optical isolation of the D/A output and transformer based isolation up to 500 VDC.
¹«Ë¾Ãû³Æ£º ACTRLRUN-¿ÆÈÕй¤¿Ø
µç »°£º 010 51659880 / ÀîÔÆÁú
ÊÖ»ú£º 13901227430
µØ Ö·£º ±±¾©Êк£µíÇøËÕÖݽÖ18ºÅ³¤Ô¶ÌìµØ´óÏÃA1×ù16²ã
ÓÊ ±à£º 100080
Ö÷ Ò³£º http://www.krxic.com.cn
  • KPCI-882 2Öá²½½øµç»úÔ˶¯¿ØÖÆ¿¨
  • PCI-1240U ËÅ·þµç»úÔ˶¯¿ØÖÆ¿¨
  • PCL-839+ 3Öá²½½øµç»ú¿ØÖÆ¿¨
  • ADAM-5240 4Öá²½½ø/Âö³åËÅ·þµç»úÄ£¿é
  • ²½½øµç»úÇý¶¯Æ÷KRX-42A-2H
  • ²½½øµç»úÇý¶¯Æ÷KRX-57A-2H
  • ²½½øµç»úÇý¶¯Æ÷KRX-57A-3H
  • ²½½øµç»úÇý¶¯Æ÷KRX-86A-2H
  • ²½½øµç»úÇý¶¯Æ÷KRX-86A-3H
  • ²½½øµç»úÇý¶¯Æ÷KRX-110A-2H
