¾µ·´Éäʽ ²âÁ¿·¶Î§£º0.15 ... 70/150/300Ã× ¾«È·¶È£º¡À 2/¡À 3/¡À 5ºÁÃ× Êý¾Ý½çÃæ£ºSSI, Profibus, RS 422, DeviceNet,HIPERFACE
Model Name |
Part Number |
Reproducibility |
Response time |
Accuracy |
Distance from ... to |
DME5000-121 |
1024083 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-111 |
1022949 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-112 |
1023668 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-113 |
1025048 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-114 |
1025832 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-115 |
1025833 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-122 |
1024084 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-123 |
1025249 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-124 |
1025836 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-211 |
1024081 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-212 |
1024082 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-213 |
1025250 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-214 |
1025834 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-215 |
1025835 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-221 |
1024085 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-222 |
1024086 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-223 |
1025251 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-224 |
1025837 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-311 |
1025244 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-312 |
1025245 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-313 |
1025252 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-314 |
1026002 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-315 |
1026003 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-321 |
1025246 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-322 |
1025247 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-323 |
1025253 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-324 |
1026004 |
4 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-117 |
1028243 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-127 |
1028244 |
0.5 mm |
+- 2 mm |
0,15 ... 70 m |
DME5000-217 |
1028245 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-227 |
1028246 |
1 mm |
+- 3 mm |
0,15 ... 150 m |
DME5000-317 |
1028247 |
2 mm |
+- 5 mm |
0,15 ... 300 m |
DME5000-327 |
1028248 |
2 mm |
+- 5 mm |
0,15 ... 300 m | |
