Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Ê©¿Ë Âþ·´Éäʽ¹âµç¿ª¹Ø ±³¾°ÕÚ±ÎBGS WT12L-2 Laser £¨Ð¡ÐÍ£©
²úÆ·Ãû³Æ£º Ê©¿Ë Âþ·´Éäʽ¹âµç¿ª¹Ø ±³¾°ÕÚ±ÎBGS WT12L-2 Laser £¨Ð¡ÐÍ£©
ÐÍ ºÅ£º WT12L-2 Laser £¨Ð¡ÐÍ£©
Æ· ÅÆ£º 96
¼¤¹âµÈ¼¶2¼¶
¿ÉÐýת900µÄM12²åÍ·»ò2mµçÀÂ
¿Éµ÷УºÍ¹Ì¶¨µÄ±³¾°Õڱι¦ÄÜ
Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
WT12L-2B510 1017959 15 x 49 x 41,5 mm Connector, M12, 5-pin 20 ... 50 mm
WT12L-2B530 1018250 15 x 49 x 41,5 mm Connector, M12, 5-pin 30 ... 200 mm
WT12L-2B540 1018251 15 x 49 x 41,5 mm Connector, M12, 5-pin 30 ... 200 mm
WT12L-2B550 1017904 15 x 49 x 41,5 mm Connector, M12, 5-pin 30 ... 200 mm
WT12L-2B500S41 1023013 15 x 49 x 415 mm Connector, M12, 5-pin 30 ... 60 mm
¹«Ë¾Ãû³Æ£º ¹ãÖÝÊÐÎ÷¿Ë´«¸ÐÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 020 28823600 / ¹ãÖÝÊÐÎ÷¿Ë´«¸ÐÆ÷ÓÐÏÞ¹«Ë¾
ÊÖ»ú£º
µØ Ö·£º ¹ãÖÝÊÐÌìºÓÇøÖé½­Î÷·15ºÅÖé½­³Ç´óÏÃ18Â¥
ÓÊ ±à£º 510623
Ö÷ Ò³£º www.sick.com
  • һάÂëÔĶÁÆ÷CLV602 ÉÏÊÐÀ²£¡
  • Î÷¿ËÐÂÆ·|VMS6200 ÐÐÀî¼°ÍÐÅ̼ì²âϵͳ
  • Î÷¿Ë °²È«Î»Öÿª¹Ø-I10-PA213/I10-RA213
  • Î÷¿Ë ͨµÀ·À»¤ÏµÍ³-Safe Entry Exit
  • Î÷¿Ë Visionary- S 3DÊÓ¾õ²ð¶âϵͳ
  • SICKÐÂÒ»´ú¸ßËÙ·ÖÌåʽ3DÏà»úRanger3
  • Î÷¿Ë CFP¡ª¡ª×î°Ù´îµÄҺλ´«¸ÐÆ÷
  • Î÷¿Ë¿áìÅ3D¿Æ¼¼¡ªTOF 3DÏà»ú
  • Î÷¿Ë ATM60¾ø¶ÔÖµÐͱàÂëÆ÷£ºÐÔÄܿɿ¿£¬Îȶ¨ÐÔÇ¿£¬Ä£¿é»¯Éè¼Æ
  • IMF ÎÀÉúÐͽӽü´«¸ÐÆ÷
