产品介绍: |
WT12-2 红色光源 可屏蔽周围环境光源 可旋转900的M12插头或2m电缆 可调校的前景遮蔽和检测距离
| Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WT12-2N140 |
1016145 |
15 x 49 x 41,5 mm |
Cable, 2 m |
35 ... 100 mm |
WT12-2N440 |
1016146 |
15 x 49 x 41,5 mm |
Connector, M12, 4-pin |
35 ... 100 mm |
WT12-2P140 |
1016148 |
15 x 49 x 41,5 mm |
Cable, 2 m |
35 ... 100 mm |
WT12-2P440 |
1016150 |
15 x 49 x 41,5 mm |
35 ... 100 mm |
