Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ´¥¿Ø´óʦPanelMaster רÓÃÈí¼þ
²úÆ·Ãû³Æ£º ´¥¿Ø´óʦPanelMaster רÓÃÈí¼þ
ÐÍ ºÅ£º
²úÆ·´úºÅ PanelMaster-soft
²úÆ·Ãû³Æ ´¥¿Ø´óʦPanelMaster PV ϵÁÐרÓÃÈí¼þ
²úƷ˵Ã÷
Features
1. A project manages many Panels.
2. Supports 90 degree angles screen function to work out Vertical Panels.
3. Supports wisdom debug guiding while compiling
4. Supports objects enable/prohibit and visible/invisible control.
5. Supports project / macro program protected by password.
6. Supports object properties settings can be saved as initial settings.
7. Supports daylight-saving time adjustment.
8. Supports control block/ static block mode.
9. Supports HMI/WIN CE/IPC crossover hardware platforms.
10. Supports multi-languages versions. Can switch languages easily.
11. Easy to arrange the toolbar, icons and text effects in the operating software.
Language / Text management:
1. Supports any size of text for in Windows XP system.
2. Size£ºMinimize 6x8.
3. Use Unicode text code system, supports online switching.
4. Allows maximize 10 languages online switching.
5. The text formates in objects can be individual assigned for separate languages.
Graphic/ Screen management:
1. Supports ten-key design.
2. Enable / disable screens. Supports new function objects, for example, slide analog switch
3. Supports graphic, Bmp/JPG/Gif dynamic graphic.
4. Supports tag function, provides assigning read and write addresses in objects.
5. Supports 16 grays / 256 colors / 65535 colors
6. Preview the objects after setting.
Data management:
1. Multi-block multi-bits/ words Alarm management. (Maximize 16 bloc
2. Multi-block Recipe management. (Maximize 16 blocks)
3. Multi-block Historical data sampling. (Maximize 16 blocks)
4. Supports projects files and macro programs protection.
5. Import/Export management.
6. Supports data download and upload.
7. Supports trigger data recording, saving and chasing.
Communication advantages:
1. Supports multi-driver communication.
2. Supports intelligent auto-downloading. Auto detects download communication port.
3. Supports off-line simulation / on-line simulation. PC transparent communicates with PLC is possible.
4. Supports Touch Type / Key Type for different applications need
¹«Ë¾Ãû³Æ£º ÉîÛÚ˹ÃÀÌØ¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83572781 / лÈÙÎÄ
ÊÖ»ú£º
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÌì°²ÊýÂë³ÇÌìÏé´óÏÄCD×ù12C2
ÓÊ ±à£º 528000
Ö÷ Ò³£º http://www.cermate.com
  • 3.5´ç²ÊÉ«´¥ÃþʽÈË»ú½çÃæ
  • 5.7´çµ¥É«´¥¿ØÊ½ÈË»ú½çÃæ
  • 8.4´ç¸ß²Ê65535É« TFT ´¥¿ØÆÁ
  • ´¥¿Ø´óʦPanelMaster רÓÃÈí¼þ
  • 10.4´ç¸ß²Ê65535É«TFT LCD´¥¿ØÆÁ
  • 12.1´ç¸ß²Ê65535É«TFT ´¥¿ØÆÁ
  • 8.0´ç65535É«¸ß²Ê´¥¿ØÆÁ
  • 5.7´çPLϵÁÐ
  • 17´çÓ|¿ØÊ½ÎžÄ»Ö÷°æ
  • 12.1´çÓ|¿ØÊ½ÎžÄ»
