Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ³¡ÐÅÁîÒÇ(¶à·ЭÒé·ÖÎöÒÇ)
²úÆ·Ãû³Æ£º ³¡ÐÅÁîÒÇ(¶à·ЭÒé·ÖÎöÒÇ)
ÐÍ ºÅ£º MPA7300 MPA7200 MPA7100
³§¼Ò GN Nettest
¹ÙÍø½éÉÜ Ïêϸ½éÉÜ PDF
°üº¬ËùÓÐÖ÷ÒªµÄµçÐÅЭÒ飺SS7, DASS2, DPNSS, BTNR167, GSM, ETSI Q931, INAP µÈµÈ.
Ëù Åä Ä£ ¿é
MPA7300 Multi Processor *2 2 Mbit/s Unbalanced Quad Link *1 -
MPA7300 Multi Processor *3 ¡¡ ¡¡
MPA7300 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1 2 Mbit/s Balanced Quad Link *1
MPA7200 Multi Processor *2 2 Mbit/s Unbalanced Quad Link *5 PCI Link Interface *1
MPA7200 PCI Controller *2 2 Mbit/s Unbalanced Quad Link *6 -
MPA7100 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1 ¡¡
MPA7100 Multi Processor *1 2 Mbit/s Unbalanced Quad Link *1 -
¡ôϵͳÈí¡¢Ó²¼þÐÔÄܷdz£Îȶ¨£¬Ó¦Óü«Æä¹ã·º£¬¼¼Êõ·þÎñÈ«Ãæ×¨Òµ
¡ôÏȽøµÄÓ²¼þ½á¹¹£¨Ç°ºǫ́´¦Àí·Ö¿ª£©£¬³¬´óÈÝÁ¿´¦ÀíÄÜÁ¦£¨ÉϰÙСʱ²»¼ä¶Ï¼Ç¼£©±£Ö¤Êý¾Ý´¦Àí¿ìËÙ¿É¿¿£¬ÖçÒ¹²»¼ä¶Ï
¡ôËùÓйæ³Ìͬʱ½âÂ룬¿çÁ´Â·ÊµÊ±¸ú×Ùºô½Ð£¬±£Ö¤¿ìËÙ¹ÊÕ϶¨Î»
¡ô×Ô¶¯Ê¶±ðÐÅÁî¼°ÏûÏ¢ÐòÁдíÎ󣬸ø³ö¸æ¾¯
¡ôÖÇÄÜ»¯×Ô¶¯ËÑË÷ÐÅÁîʱ϶
¡ô¶àÖÖÓ¦ÓãºÐÅÁîÅäºÏ¡¢ºô½Ð×·×Ù¡¢½ÓͨÂÊ·ÖÎö¡¢ºôËð·ÖÎö¡¢ÍøÂç¹æ»®¡¢GSMÍøÂçÓÅ»¯£¬MAP²ãÔöÖµÒµÎñ¿ª·¢¡¢Íø¹Ø¼Æ·ÑÑéÖ¤£¬ÆÛÕ©¼ì²â¡¢ÍøÂç¸æ¾¯¼à²âµÈ
¡ôODBC¿ª·ÅÊý¾Ý¿â¸ñʽ¼°ÖÐÎĽçÃæ
¡ôÖÐÎIJÙ×÷½çÃæ·ÂÕæÉè¼Æ ÌṩÓѺõÄÈË»ú½»»¥½çÃæ£¬ÏµÍ³²Ù×÷¼òµ¥Ò×ѧ¡£
ϵͳ±ê×¼ÅäÖÃ
²Ù×÷ϵͳ Microsoft Windows2000
CPU Pentium 400MHz
RAM 128MB
ÏÔʾģʽ SVGA,TFTÕæ²ÊÉ«
»º´æ 1Gbyte disk on the MPU
Ó²ÅÌ 12GB
Used for acceptance testing, detailed trouble shooting, daily maintenance and performance analysis of telecoms networks and switches.
¶à´ï10ÖÖЭÒéͬʱ·ÖÎö¡£Easy to use multi-link instrument with true multi-protocol analysis capability for up to ten protocols simultaneously.
Ability to store 1GB of data with 1ms resolution, filter trigger and perform sequence recording for easy analysis.
ЭÒé·ÖÎö
ЭÒé·ÖÎö¹¦Äܲ¶»ñ·¢³öµÄÐźŵ¥Ôª²¢ÒÔ½âÂëµÄÐÎʽÏÔʾ¡£The protocol-analysis function captures signaling units and displays them in decoded form. The captured signaling units in the log are time-stamped with a resolution of 1 millisecond. The MPA 7300provides full correlation of signaling information recorded from all connected signaling links. Different protocol descriptions may be associated with the various signaling-link interfaces. National protocol descriptions can easily be customized. Automatic error recognition The unique MPA 7300 expert system automatically recognizes all invalid signaling messages and sequences (all valid messages and sequences are contained in the protocol description). In case of a signaling error (syntax error, messages out of sequence or timeout between two messages), the collected events will be stored with an error message in the log.
Â˲¨Æ÷
In this context, filtering means controlling which signaling messages/sequences and alarms are stored in the event log. An event recognizer in the MPA 7300 is a mechanism that allows the user to look for individual signaling messages and alarms with a specific content ¨C e.g. ISUP RELease messages with cause 17 ¡°user busy¡±. Sequence recognizers are used to capture a complete sequence of events forming a meaningful transaction ¨C e.g. a telephone call or a Service 800 IN transaction. Both event recognizers and sequence recognizers can be used as filter conditions. The user can select from a wide range of predefined ¡°click-and-go¡± events and sequence recognizers. Up to 500 concurrent calls/transactions can be followed by a sequence recognizer.
´¥·¢ÀàÐÍ
The MPA contains two trigger types: One start trigger for enabling (open) storage of events and one stop trigger for disabling (close). An event recognizer can be selected as start trigger. A timing offset or event-number offset can also be specified before the event recognizer.
Replacement for the successful ETP-71 protocol analyser
Incorporates a Windows® GUI with pentium processor, 10.4" screen and remote control capability
Includes all major telecoms protocols such as SS7, DASS2, DPNSS, BTNR167, GSM, ETSI Q931, INAP etc
¶þÊÖÒÇÆ÷;010-62123258 ÓÊÏä:buy17@126.com
¹«Ë¾Ãû³Æ£º ±±¾©Êб±·½Ë¼Ô´µç×Ó¼¼ÊõÖÐÐÄ
µç »°£º 010 62123259 / ÁõÁè
ÊÖ»ú£º 13241735460
µØ Ö·£º º£µíÇø´óÁøÊ÷±±Õ¾¸»º£ÖÐÐÄ4-105
ÓÊ ±à£º 100081
Ö÷ Ò³£º http://www.buy17.com
  • AM8e E1 PCM / VF ºô½Ð·ÖÎöÒÇ
  • ÎÞÏßµç×Û²âÒÇ CMS50
  • ÉäÆµÌøÆµÐźÅÔ´ Agilent/HP8645A
  • É䯵Ðźŷ¢ÉúÆ÷ R&S SMIQ02
  • ¸ßƵÔëÉùÄ£Äâ·¢ÉúÆ÷ INS-4001
  • Ë«¼«µçÔ´ PBX40-2.5 (Õý¸ºµçÔ´)
  • Agilent 54832D »ìºÏÐźÅʾ²¨Æ÷
  • Ameritec AM2-A Ä£Äâºô½Ð·¢ÉúÆ÷
  • Êý×ִ洢ʾ²¨Æ÷ HP54602B
  • Æßλ°ëÊý×ÖÍòÓñí R6871E
