ÐͺÅ
 OESA32G1
 OESA63G1
 OESA100G1
 OESA160B3
 OESA200B3PL1
 OESA250B3PL1
 OESA315B3PL1
 OESA400B3PL1
 OESA630B3PL1
 OESA800B3PL1
 Fuse Switches OESA
 OESA ÈÛ¶ÏÆ÷×鿪¹Ø²Î¿¼Ãæ¼Û
 4-Pole Flush Mount Fuse Switches, w/o Fuse Links - BS Standard
 Ëļ«Ç¶ÈëʽÈÛ¶ÏÆ÷×鿪¹Ø£¬²»º¬ÈÛË¿ - BS ±ê×¼¹æ¸ñ
 ÐͺÅ
 OESA32G4
 OESA63G4
 OESA100G4
 OESA160B4
 OESA200B4PL1
 OESA250B4PL1
 OESA315B4PL1
 OESA400B4PL1
 OESA630B4PL1
 OESA800B4PL1
 List Price for Fuse Switches OESA
 3-Pole Flush Mount Fuse Switches, w/o Fusw Links - DIN Standard
 Èý¼«Ç¶ÈëʽÈÛ¶ÏÆ÷×鿪¹Ø£¬²»º¬ÈÛË¿ - DIN ±ê×¼¹æ¸ñ
 ÐͺÅ
 OESA00-32
 OESA00-63
 OESA00
 OESA00-160
 OESA250D3PL
 OESA400D3PL
 OESA630D3PL
 OESA800D3PL
 4-Pole Flush Mount Fuse Switches, w/o Fusw Links - DIN Standard
 Ëļ«Ç¶ÈëʽÈÛ¶ÏÆ÷×鿪¹Ø£¬²»º¬ÈÛË¿ - DIN ±ê×¼¹æ¸ñ
 ÐͺÅ
 OESA00-32A4
 OESA00-63A4
 OESA00A4
 OESA00-160A4
 OESA250D4PL
 OESA400D4PL
 OESA630D4PL
 OESA800D4PL
 Fuse Switches OESA Accessories
 OESA ÈÛ¶ÏÆ÷×鿪¹Ø¸½¼þ²Î¿¼Ãæ¼Û
 ÐͺÅ
 Extended Shaft
 ¼Ó³¤Öá
 OXP12X185
 OXP6X150
 OXP6X210
 OXP6X290
 OXP6X360
 OXP6X430
 OXP12X166
 OXP12X250
 OXP12X325
 OXP12X395
 OXP12X465
 OXP12X535
 Optional Handle, Front Operated
 °åǰ²Ù×÷ÊÖ±ú
 OHB65J6
 OHG65J6
 OHY65J6
 OHB80J6
 OHG80J6
 OHY80J6
 OHB125J12
 OHG125J12
 OHY125J12
 OHB145J12
 OHG145J12
 OHY145J12
 YASDA7
 YASDA8
 Conversion Kits
 ת»»Ì×¼þ
 OESAZW2
 OETLZW9
 OESAZW1
 OETLZW11
 OETLZW12
 OETLZW13
 OETLZW3
 OETLZW14
 OETLZW15
 OETLZX95
 ÐͺÅ
 Netural Links
 ÖÐÐÔÏß
 OESAZX87
 OESAZX118
 OESAZX86
 OESAZX85
 OESAZX88
 Motor Operator
 µç¶¯»ú²Ù×÷Æ÷
 OEMO001/220VAC
 OEMO002/220VAC
 OEMO003/220VAC
 OEMO004/220VAC
 OEMO101/220VAC
 OEMO202/220VAC
 OEMO303/220VAC
 Auxiliary Contact Sets
 ¸¨Öú´¥Í·×é
 OESAZX32
 OESAZX16
 OESAZX33
 OESAZX17
 OESAZX126
 OESAZX25
 OZXK1
 OZXK2
 OZXK3
 OZXK4
 OZXK5
 OZXK6
 ÐͺÅ
 Shrouds for auxiliary contacts
 ¸¨Öú´¥Í·±£»¤ÕÖ
 OESAZX34
 OESAZX35
 OESAZX26
 OESAZX19
 OESAZX23
 Fuse Cover
 ÈÛ¶ÏÆ÷¸Ç
 OESAZX172
 OESAZX173
 OESAZX3
 OESAZX74
 OESAZX80
 Fuse Cover Interlock Kit
 ÈÛ¶ÏÆ÷¸ÇÁªËø×é¼þ
 OESAZX83
 Electronic Blown Fuse Monitor
 µç×ÓÈÛ¶ÏÆ÷ÈÛ¶Ïָʾ
 OFM690
 Load Break Switches OETL
 OETL ¸ººÉ¿ª¹Ø²Î¿¼Ãæ¼Û
 3-Pole Flush Mount Load Break Switches
 Èý¼«Ç¶Èëʽ¸ººÉ¿ª¹Ø
 ÐͺÅ
 OETL200K3
 OETL250K3
 OETL315K3
 OETL400D1
 OETL630K3
 OETL800K3
 OETL1000K3
 OETL1250K3
 OETL1600K3
 OETL2500K3
 OETL3150K3
 4-Pole Flush Mount Load Break Switches
 Ëļ«Ç¶Èëʽ¸ººÉ¿ª¹Ø
 ÐͺÅ
 OETL200K4
 OETL250K4
 OETL315K4
 OETL400D4
 OETL630K4
 OETL800K4
 OETL1000K4
 OETL1250K4
 OETL1600K4
 OETL2500K4
 OETL3150K4
 OETL Accessories
 OETL ¸ººÉ¿ª¹Ø¸½¼þ²Î¿¼Ãæ¼Û
 ÐͺÅ
 Extended Shafts
 ¼Ó³¤Öá
 OETLZS37
 OETLZS55
 OETLZS57
 OXP8X140
 OXP8X240
 OXP8X340
 OXP8X500
 OXP12X166
 OXP12X185
 OXP12X250
 OXP12X325
 OXP12X395
 OXP12X465
 OXP12X535
 Optional Handles , Front Operated
 °åǰ²Ù×÷ÊÖ±þ
 OHB80J8
 OHG80J8
 OHY80J8
 OHB145J12
 OHG145J12
 OHY145J12
 YASDA7
 YASDA8
 Coversion Kits
 ת»»Ì×¼þ
 OETLZW8
 OETLZW18
 OETLZW9
 OETLZW6
 OETLZW20
 OETLZW11
 OETLZW12
 OETLZW17
 OETLZW21
 OETLZW13
 OETLZW19
 OETLZW3
 OETLZW14
 OETLZW15
 OETLZX95
 Load Break Switches OETL Accessories
 ÐͺÅ
 Netural Links
 ÖÐÐÔ½ÓÏß
 OESAZX87
 OESAZX118
 OESAZX129
 OESAZX85
 ¸¨Öú´¥Í·×é
 OBEA10
 OBEA01
 OETLZX52
 OETLZX55
 OETLZX53
 OETLZX56
 OETLZX54
 OETLZX57
 OZXK12
 OZXK1
 OZXK13
 OZXK2
 OZXK16
 OZXK3
 OZXK14
 OZXK4
 OZXK15
 OZXK5
 OZXK17
 OZXK6
 Mounting Bases for auxiliary contacts OBEA 10 and 01
 ¸¨Öú´¥Í·°²×°×ù
 OETLZX142
 OETLZX143
 OETLZX144
 Switch - Disconnector OT
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 3-Pole Switch-Disconnector Base and DIN-Rail Mounting
 Èý¼«¸ôÀ뿪¹Ø - µ×¼°DIN µ¼¹ì°²×°
 ÐͺÅ
 OT16E3
 OT25E3
 OT32E3
 OT45E3
 OT63E3
 OT80E3
 OT100E3
 OT125E3
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 4-Pole Switch-Disconnector Base and DIN-Rail Mounting
 Ë𢡊ôÀ뿪¹Ø - µ×¼°DIN µ¼¹ì°²×°
 ÐͺÅ
 OT16E4
 OT25E4
 OT32E4
 OT45E4
 OT63E4
 OT80E4
 OT100E4
 OT125E4
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 Front Operated Switch-Disconnector
 Ç°Ãæ²Ù×÷¸ôÀ뿪¹Ø
 ÐͺÅ
 OT125A3
 OT125A4
 OT160E3
 OT160E4
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 3-Pole Switch-Disconnector Door Mounting
 Èý¼«¸ôÀ뿪¹Ø - Ãæ°å°²×°
 ÐͺÅ
 OT16ET3
 OT25ET3
 OT32ET3
 OT45ET3
 OT63ET3
 OT100ET3
 OT125ET3
 OT160ET3
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 4-Pole Switch-Disconnector Door Mounting
 Ë𢡊ôÀ뿪¹Ø - Ãæ°å°²×°
 ÐͺÅ
 OT16ET4
 OT25ET4
 OT32ET4
 OT45ET4
 OT63ET4
 OT100ET4
 OT125ET4
 OT160ET4
 OT ¸ôÀ뿪¹Ø²Î¿¼Ãæ¼Û
 3-Pole Plastic Enclosed Switch
 Èý¼«·â±Õʽ¿ª¹Ø
 ÐͺÅ
 OTP25B3P
 OTP32B3P
 OTP45B3P
 OTP63B3P
 OTP80B3B
 OTP125B3B
 Switch - Disconnector OT Accessories
 OT ¸ôÀ뿪¹Ø¸½¼þ²Î¿¼Ãæ¼Û
 ÐͺÅ
 Auxiliary Contacts
 ¿¨×°¸¨Öú´¥Í·
 OA1G01
 OA1G10
 Fourth Poles
 µÚËļ«
 OTPS32EP
 OTPS32ED
 OTPL32EP
 OTPL32ED
 Additional Poles
 ¸½¼Ó¼«
 OTPN32EP
 OTPN32ED
 OTPD32EP
 OTPD32ED
 OTPE32EP
 OTPE32ED
 Terminal Shrouds for 3-Pole Switches
 ͸Ã÷±£»¤°å
 OTS32T3
 OTS63T3
 Terminal Shrouds for 4-Pole Switches
 ͸Ã÷±£»¤°å
 OTS32T1
 OTS63T1
 Handles for based mounted switches
 ²Ù×÷ÊÖ±ú
 OHB1AH
 OHY1AH
 OHS1AH
 OHG1AH
 OHB1AH1
 OHY1AH1
 OHS1AH1
 OHG1AH1
 OHB2AJ
 OHY2AJ
 OHS2AJ
 OHG2AJ
 OHB2AJ1
 OHY2AJ1
 OHS2AJ1
 OHG2AJ1
 ÐͺÅ
 Handles for door mounted switches, snap-on mounting
 ²Ù×÷ÊÖ±ú - Ãæ°åʽ°²×°ÊÊÓÃ
 OHB1PH
 OHY1PH
 OHS1PH
 OHG1PH
 OHB2PJ
 OHY2PJ
 OHS2PJ
 OHG2PJ
 Handles for door mounted switches, screw mounting
 ²Ù×÷ÊÖ±ú - ÂÝ˿ʽ°²×°ÊÊÓÃ
 OHB1RH
 OHY1RH
 OHS1RH
 OHG1RH
 OHB2RJ
 OHY2RJ
 OHS2RJ
 OHG2RJ
 Shaft for based mounted switches
 ÖáÐÄ
 OXS5X85
 OXS5X105
 OXS5X120
 OXS5X180
 OXS5X330
 Extended Shafts
 ¼Ó³¤Öá
 OXP6X150
 OXP6X210
 OXP6X290
 OXP6X360
 OXP6X430
 Optional Handles, Front Operated
 °åǰ²Ù×÷ÊÖ±ú
 OHB65J6
 OHG65J6
 OHY65J6
 OHB125J12
 OHG125J12
 OHY125J12
 Conversion Kits
 ת»»³ÉÌ×¼þ
 OESAZW2
 OESAZW1
 ÐͺÅ
 ¸¨Öú´¥Í·×é
 OBEA10
 OBEA10AU
 OBEA01
 OBEA01AU
 Mounting Bases for Auxiliary Contact OBEA 10 and 01
 ¸¨Öú´¥Í·°²×°µ××ù
 OEZNP1
 Fuse Link OFAA, Universal Fuses
 OFAAÈÛ¶ÏÆ÷-ͨÓÃÐͲο¼Ãæ¼Û
 ÐͺÅ
 OFAA00H2
 OFAA00H4
 OFAA00H6
 OFAA00H10
 OFAA00H16
 OFAA00H20
 OFAA00H25
 OFAA00H35
 OFAA00H50
 OFAA00H63
 OFAA00H80
 OFAA00H100
 OFAA00H125
 OFAA1H16
 OFAA1H20
 OFAA1H25
 OFAA1H32
 OFAA1H35
 OFAA1H40
 OFAA1H50
 OFAA1H63
 OFAA1H80
 OFAA1H100
 OFAA1H125
 OFAA1H160
 OFAA1H200
 OFAA1H250
 OFAA2H160
 OFAA2H200
 OFAA2H250
 OFAA2H315
 OFAA2H400
 OFAA3H315
 OFAA3H400
 OFAA3H500
 OFAA3H630
 Fuse Link OFAM, Universal Fuses
 OFAMÈÛ¶ÏÆ÷-ͨÓÃÐͲο¼Ãæ¼Û
 ÐͺÅ
 OFAM00AM16
 OFAM00AM20
 OFAM00AM25
 OFAM00AM32
 OFAM00AM40
 OFAM00AM50
 OFAM00AM63
 OFAM00AM80
 OFAM00AM100
 OFAM00AM125
 OFAM00AM160
 OFAM1AM50
 OFAM1AM63
 OFAM1AM80
 OFAM1AM100
 OFAM1AM125
 OFAM1AM160
 OFAM1AM200
 OFAM1AM250
 OFAM2AM125
 OFAM2AM160
 OFAM2AM200
 OFAM2AM250
 OFAM2AM315
 OFAM2AM355
 OFAM2AM400
 OFAM3AM315
 OFAM3AM355
 OFAM3AM400
 OFAM3AM500
 OFAM3AM630
