型号
SR-U 00-50 3 pole 160 A- ABB Grey
SR-U 1-50 3 pole 250 A- ABB Grey
SR-U 2-50 3 pole 400 A- ABB Grey
SR-U 3-50 3 pole 630 A- ABB Grey
Slim Line SR
SR-B - 50 mm busbardistance ABB GREY
型号
SR-B 00-50 3 pole 160 A- ABB Grey
SR-B 1-50 3 pole 250 A- ABB Grey
SR-B 2-50 3 pole 400 A- ABB Grey
SR-B 3-50 3 pole 630 A- ABB Grey
Slim Line SR
SR-S - 50 mm busbardistance ABB GREY
型号
SR-SP3-50 3 pole 630 A- ABB Grey
SR-SS 3-50 3 pole 630 A- ABB Grey
Slim Line SR
SR-E - 50 mm busbardistance ABB GREY
型号
SR-E 00-50 3 pole 160 A- ABB Grey
SR-E 1-50 3 pole 250 A- ABB Grey
SR-E 2-50 3 pole 400 A- ABB Grey
SR-E 3-50 3 pole 630 A- ABB Grey
Slim Line SR
SR-M - 50 mm busbardistance ABB GREY
型号
SR-M 00-50 3 pole 160 A- ABB Grey
SR-M 1-50 3 pole 250 A- ABB Grey
SR-M 2-50 3 pole 400 A- ABB Grey
SR-M 3-50 3 pole 630 A- ABB Grey
Slim Line SR
SR-M 4-pole - 50 mm busbardistance ABB GREY
型号
SR-M 00-50 4 pole 160 A- ABB Grey
SR-M 1-50 4 pole 250 A- ABB Grey
SR-M 2-50 4 pole 400 A- ABB Grey
SR-M 3-50 4 pole 630 A- ABB Grey
Slim Line SR
SR-M 2-pole DC - 50 mm busbardistance ABB GREY
型号
SR-M 00 DC-50 2 pole 160 A- ABB Grey
SR-M 1 DC-50 2 pole 250 A- ABB Grey
SR-M 2 DC-50 2 pole 400 A- ABB Grey
SR-M 3 DC-50 2 pole 630 A- ABB Grey
Slim Line SR
SR-M - 50 BS - British Standard ABB GREY
型号
SR-M 63 A - 50 BS 3 pole- ABB Grey
SR-M 100 A - 50 BS 3 pole- ABB Grey
SR-M 200 A - 50 BS 3 pole- ABB Grey
SR-M 400 A - 50 BS 3 pole- ABB Grey
SR-M 63 A - 50 BS 4 pole- ABB Grey
SR-M 100 A - 50 BS 4 pole- ABB Grey
SR-M 200 A - 50 BS 4 pole- ABB Grey
SR-M 400 A - 50 BS 4 pole- ABB Grey
SR-M 63 A - 50 DC BS 2 pole- ABB Grey
SR-M 100 A - 50 DC BS 2 pole- ABB Grey
SR-M 200 A - 50 DC BS 2 pole- ABB Grey
SR-M 400 A - 50 DC BS 2 pole- ABB Grey
EasyLine
型号
XLP
XLP 000
XLP 00
XLP 00 6BC
SLP
SLP 1
SLP 2
SLP 3
SLP-K
SLP-K 1
SLP-K 2
SLP-K 3
SLP for Busbar system SF 60
SLP-H 00
SLP-V 00
SLP-H 00
SLP-V 00
SLP-H 1
SLP-H 1
SLP 4 Pole
SLP 00 4 pole
SLP K1 4 pole
SLP K2 4 pole
SLP K3 4 pole
SLP Variants
SLP 00 S
SLP 00 MNS
SLP 1 MNS
SLP 00-M611
SLP 00 MNS-M611
SLP 1-M611
SLP 1-MNS-M611
SLP 2-M611
SLP 3-M611
SLP 00-H95
SLP 00-H95-M611
EasyLine Accessories
型号
Front frame
Front frame
Front frame
Front frame for INS
Front frame for INS
Front fixing device complete
Front fixing bracket and front frame
Rail mounting device
Cover IP 30
Cover IP 30
Cover IP 30
Cover IP 30
Cover IP 30 4 pole
Cover IP 30 4 pole
Cover IP 30 4 pole
Cover IP 30 4 pole
Cover with fuse surveillance M611
Auxiliary contact b
Auxiliary switch h
Auxiliary switch h
Auxiliary switch h
Front fixing f/ SLP 100 / 00 / 00 4-pole
MNS Adaptor
MNS Adaptor
Cover
Cover
Cover
Busbar carrier 3P
Busbar carrier 1P
Cover f/busbar carrier
Cable conn. module
Cover for cable conn. Module
Cover for SLP H/V 00
Cover for busbar
Cover for busbar
型号
JM Single cable 70 - 150 mm2
clamps, Al/Cu 120 - 300 mm2
JM Double cable 2x70 - 150 mm2
ABB single cable clamp 16 - 150 mm2
ABB single cable clamp 16 - 240 mm2
KP Single cable calmps, Al / Cu 95 - 240 mm2
KP Double cable calmps, Al / Cu 2x95 - 240 mm2
Cable lug connection, Al/Cu 240 mm2
Cable lug connection, Al/Cu 300 mm2
For busbar connection, Al/Cu 35 mm
For busbar connection, Al/Cu 40 mm
SLBM and BSL
型号
SLBM and BSL
SLBM 250 (busbar distance 210mm)
SLBM 400 (busbar distance 210 mm)
SLBM 630 (busbar distance 210 mm)
SLBM 800 (busbar distance 210 mm)
SLBM 1200 (busbar distance 210 mm)
SLBM 1600 (busbar distance 210 mm)
SLBM 250 (busbar distance 185/210 mm)
SLBM 400 (busbar distance 185/210 mm)
SLBM 630 (busbar distance 185/210 mm)
BSL 1600 (busbar distance 210 mm)
BSL 2000 (busbar distance 210 mm)
Fuse surveillance with M611 on :
SLBM 250
SLBM 400
SLBM 630
Hood for cable terminations
Splices for 400/630 A
Kit for mounting 2xSLBM 400A = 800A
Kit for mounting 2xSLBM 630A = 1200A
Kit for mounting 3xSLBM 630A = 1600A
Cable termination 1 x 300 mm2.
Cable termination 2 x 240 mm2.
Protecting cover, for :
BSL 1600
BSL 2000
Earthing cover, type JSL
Ammeter 0-200/5, 0-400/5 A 72 x 72 mm
Transformer 200/5 A, 400/5 A
NH 2-special fuse 250 A
NH 2-special fuse 315 A
NH 2-special fuse 355 A
NH 2-special fuse 400 A
1 x Cover
2 x Brackets
Spare parts
Cover compl. for SLBM 250
Cover compl. for SLBM 400
Cover compl. for SLBM 630
FuseLine - Multi
型号
FLB
Fusebase FLB 00-100 (M8)1)
Fusebase FLB 00-185 (M8)1)
Fusebase FLB 1-B (M10)
Fusebase FLB 2-B (M12)
Fusebase FLB 3-B (M12)
Fusebase FLB 1-C
Fusebase FLB 2-C
Fusebase FLB 3-C
FLM-3P Three pole
Fuse switch disc. FLM 00-100-3P (M8)1)
Fuse switch disc. FLM 1-B3P (M10)
Fuse switch disc. FLM 2-B3P (M12)
Fuse switch disc. FLM 3-B3P (M12)
Fuse switch disc. FLM 1-C3P
Fuse switch disc. FLM 2-C3P
Fuse switch disc. FLM 3-C3P
FLM-1P Single pole
Fuse switch disc. FLM 00-185-1P (M8)1)
Fuse switch disc. FLM 1-B1P (M10)
Fuse switch disc. FLM 2-B1P (M12)
Fuse switch disc. FLM 3-B1P (M12)
Fuse switch disc. FLM 800-B1P (M12)
Fuse switch disc. FLM 1250-B1P (M12)
Fuse switch disc. FLM 1-C1P
Fuse switch disc. FLM 2-C1P
Fuse switch disc. FLM 3-C1P
Busbar coupler FLS 400-B1P (M12)
Busbar coupler FLS 630-B1P (M12)
Accessories
Cable shroud - size 00
Cable shroud- size 1, 2 or 3
Cable shroud - size 1, 2 or 3
Cable clamp for size 00-100 mm
Cable clamp for size 1, 2 or 3
Clamp strap for size 00-100 mm
Label holder size 00
Label holder size 1, 2 or 3
Adapter for size 00-100
Double adapter for size 00-100
Depth adj. for size 00 -185 mm
Spare way cover size 00-100 mm
Spare way cover size 00-185 mm
Spare way cover size 1,2,or 3
Spare way cover with adjustment
Adjusting cover for size 00-100 mm
Hooked clamp for size 00
Indicator switch for FLM size 00
Indicator switch for FLM size 1,2 or 3
Support angle
Seal carrier for sizes 1, 2 or 3
Laterable barrier FLB 00
Laterable barrier FLB 1, 2 or 3
Protective cover
SLK / FastLine
型号
Assembly plates type FS
FS 400A/150
FS 400A/250
FS 400A/400
FS 400A/600
FS 630A/400
FS 630A/600
FS 630A/800
FS 630 A/1000
FS 1200A/600
FS 1200A/800
FS 1200A/1000
Assembly plates type FST
FST 1200A/ 800
FST 1200A/1200
FST 1600A/ 800
FST 1600A/1200
FST 2500A/ 800
FST 2500A/1200
FST 2500A/800
FST 2500A/1200
Module types
DK 95 / 250 A / 50mm
DK 240/50 / 400 A / 50mm
DK 240/100 / 400 A /100mm
DK 300 / 800 A / 100mm
DS 400 / 400 A / 50mm
K 95 / 250 A / 50mm
M/P 240 / 400 A / 100mm
K 240 / 400 A / 100mm
SLK 160 / 160 A / 50mm
SLK 400 / 400 A / 150mm
SLK 630 / 630 A / 200mm
SLKD 63 / 63 A Diazed DII / 50mm
SLK-NH 160 / 160 A / 50mm
SM 200 / 200 A / 150mm
SLK-E adapters for ISOMAX
Adapter for MCCB Isomax S1
Adapter for MCCB Isomax S2
Adapter for MCCB Isomax S3
Adapter for MCCB Isomax S5
Adapter for MCCB Isomax S6
Adapter for MCCB Isomax S7
SLK / FastLine Accessories
型号
Accessories - FastLine
KJK 95
KJK 240
KJM 240
KJS 240
Contact links
Extra switch element
Extra fuse carrier
SNH 160 single pole fuse carrier
Protection cover
Protection cover
Protection cover
Copper links
Copper links
Cable holder Ø 20-40
Cable holder Ø 35-60
Cable protection
Cable protection
Cable terminal single 120-300 mm2
Cable terminal double 2 x (120-300 mm2)
PE earthing clamp
PE earthing clamp
PE earthing clamp
Cable terminal 10-95 mm2_M8
Cable terminal 95-240 mm2_M10
PEN-clamp
PEN-clamp
Bracket with 6 PEN clamps
PEN clamp with bracket
PEN-bar 350 mm
PEN-bar 500 mm
PEN-bar 700 mm
PEN-bar 900 mm
PEN-bar 1100 mm
Neutral isolator
Cable terminal torque spanner
Insulated hexagon key NV 6
Extension NV 6 for torque spanner
Blind cover (50 mm)
Operating handle
FST-link 1600-S/B
FST-link 1600-S
FST-link 1600-E/B
FST-link 1600-E
FST-link 2500-S/B
FST-link 2500-S
FST-link 2500-E/B
FST-link 2500-E
FST 800 installation material
FST 1200 installation material
THF 三次谐波滤波器参考面价
with guard unit and bypass contactor (steel sheet enclosure)
带防护单元的和旁路接触器 (钢板箱)
型号
THF25NV
THF63NV
THF125NV
THF125NLV
THF160NV
Third Harmonic Filter
THF 三次谐波滤波器参考面价
without guard unit and bypass contactor (steel sheet enclosure)
(can be usded parallel with the THF_NV types and with connection box THF1BV)
不带防护单元的和旁路接触器 (钢板箱)
(能与 THF_NV 型和 THF 1BV 连接箱并联)
型号
THF63N
THF125N
THF160N
Parallel Connection Box
并联箱参考面价
with guard unit and bypass contactot (steel sheet enclosure)
带防护单元的和旁路接触器 (钢板箱)
型号
THF1BV1
THF1BV2
Guard Unit Box
远程监测防护单元参考面价
型号
THF 1V
