ǶÈëʽµ¥´®¿Ú·þÎñÆ÷ SE1001T µ¥´®¿Ú£¬TTL½çÃæ ; 10/100Mbps×ÔÊÊÓ¦ÒÔÌ«Íø ; Ìṩ4·Âß¼I/OÉèÖÃ; 5V»ò3.3VÊäÈëµçѹ£¬0¡æ~60¡æ¿í¹¤×÷ÎÂ¶È ; Ìṩ»ùÓÚTelnet¡¢webä¯ÀÀÆ÷¡¢´®¿Ú¿ØÖÆ¡¢windowsµÈ¶àÖÖÅäÖ÷½Ê½ ; ÌṩCÓïÑÔÈí¼þ¿ª·¢°ü£¬·½±ã¶þ´Î¿ª·¢ºÍ±à³Ì ; ¹æ¸ñ ¡¡ CPU ÄÚǶµÄ16-bit CPU £¨100MHz£© FlashÈÝÁ¿ 512 KBytes SDRAM 512 KBytes EEPROM 512 Bytes ÍøÂç½çÃæ 10/100Mbps¿ìËÙÒÔÌ«Íø ÍøÂçÐÒé TCP/IP, UDP, SNMP Read, HTTP, Telnet, ARP, BOOTP ÖØÖà ÄÚ½¨ÖØÖüü²¢×Ô¶¯´æ´¢ ¿´ÃŹ·Ê±¼ä 1.34 ÃëÓ²¼þ×Ô¶¯»Ö¸´ µÍѹµçÔ´×Ô¶¯Õì²â ͨѶģʽ TCP Server,TCP Client,UDP,ÐéÄâ´®¿ÚVirtual COM ´®¿Ú µ¥´®¿Ú, TTL½çÃæ£¬Ë«ÅÅÕë ´®¿ÚͨѶ ËÙÂÊ: 1200-230400 bps ¡¡ Êý¾Ýλ: 7 »ò 8 ¡¡ ¼ìÑé: None, Even, Odd, Mark, Space ¡¡ ֹͣλ: 1 or 2 Á÷Ïò¿ØÖÆ: Xon/Xoff, RTS/CTS 4 GPIO LED ָʾ ָʾÊä³öÐźÅÓÐRUN, LAN, COM µçÔ´ÒªÇó +5VDC@300mA ÎÂ¶È ²Ù×÷ζÈ: 0¡æ to 60¡æ, ´æ´¢Î¶È: -40¡æ to 70¡æ Ïà¶Ôʪ¶È 20%-90% ÎÞÄý¶ ³ß´ç 45mmx36mmx20mm (D x W x H) Ö§³Ö²Ù×÷ϵͳ »ùÓÚWindowsµÄ²Ù×÷ϵͳ ÅäÖà Web(HTML), Telnet,¼°ÆäËûÅäÖù¤¾ß ¶©¹ºÐÅÏ¢ SE1001T µ¥´®¿Ú£¬°å¿¨¼¶£¬Pin-headerÅÅÁÐ SE1001T-EVM ²âÊÔÄ£¿é£º¿ÉÑ¡ ²úÆ·ÅäÌ×£ºAtopÈí¼þ°²×°¹âÅÌ£¨º¬SDK£©£¬Óû§Ê¹ÓÃÊÖ²á
