¹æ ¸ñ
| CPU |
¸ßЧÄܺËÐÄ´¦ÀíÆ÷IDT 150MHZ 32bit RISC |
| FlashÈÝÁ¿ |
8M Bytes Óû§¿ÉÓà 5M |
| DDR RAM |
32M Bytes |
| EEPROM |
2 KBytes |
| Ethernet ½Ó¿Ú |
10/100M RJ45*2£¬È«Ë«¹¤×ÔÊÊÓ¦Íø¿Ú |
| ´®¿ÚÅäÖÃ |
2 ports´®¿Ú£¬TTL ¡¢RS-232/422/485 |
| ÅäÖ÷½Ê½ |
WindowsÏÂÈí¼þÅäÖã¬WebÒ³Ãæ»òTelnet·½Ê½ÅäÖÃÏà¹Ø²ÎÊý |
| ¿ª·¢»·¾³ |
Red-Hat Linux 9.0,ÄÚ²¿ÏµÍ³ÔËÐÐMips-Linux, ´øMMUÄÚ´æ¹ÜÀí£¬ |
ÌṩC/C++ÓïÑÔÈí¼þ¿ª·¢°ü£¬·½±ã¿ª·¢ºÍ±à³Ì |
| ÖØÖÃ |
ÄÚ½¨ÖØÖüü×Ô¶¯»Ö¸´³ö³§ÉèÖà |
| Ó²¼þ¹· |
ÌṩÈíÓ²¼þ¹·£¬Óû§¿É×Ô¶¨Òå |
| ʱÖÓ |
ÄÚǶʵʱʱÖÓ |
| µçÔ´ÒªÇó |
DC+5V |
| ³ß´ç |
90mm(L),70mm(W),20mm(H) |
| ÎÂ¶È |
²Ù×÷ζÈ: 0~60¡æ, ´æ´¢Î¶È: -40~70¡æ |
| Ïà¶Ôʪ¶È |
20~90% ÎÞÄý¶ |
| ¶©¹ºÐÅÏ¢ |
SE1302 |
| CPU |
IDT 336 ¨C150 , MIPS32 Core |
| FlashÈÝÁ¿ |
8M Bytes£¬5M BytesÓû§±à³Ì¿Õ¼ä |
| SDRAM |
32M Bytes |
EEPROM
2K Bytes |
| ÍøÂç½çÃæ |
Ethernet 10/100Base-TX * 2£¬ÈßÓలȫ±£ÕÏ |
| ÍøÂçÐÒé |
TCP/IP, UDP, SNMP Read, HTTP, Telnet, ARP, BOOTP |
| ÖØÖÃ |
ÄÚ½¨ÖØÖüü²¢×Ô¶¯´æ´¢ |
| ¿´ÃŹ· |
ÌṩÈí¼þ¼°Ó²¼þ¹·(¿É×Ô¶¨Òå) |
| ´®¿Ú |
2¸ö RS-485/422/232´®¿Ú£¨Èí¼þÑ¡Ôñ£© |
| ´®¿ÚͨѶ |
ËÙÂÊ: 1200-921600 bps |
Êý¾Ýλ: 7 »ò 8 |
¼ìÑé: None, Even, Odd, Mark, Space |
ֹͣλ: 1 or 2 Á÷Ïò¿ØÖÆ: Xon/Xoff, RTS/CTS |
| Êý×ÖI/O |
4 GPIO |
| LED ָʾ |
ָʾÊä³öÐźÅÓÐRUN, LAN, COM |
| µçÔ´ÒªÇó |
DC3.3V»ò5V 2.4Watt. |
| ÎÂ¶È |
²Ù×÷ζÈ: 0¡æ to 60¡æ, ´æ´¢Î¶È: -40¡æ to 70¡æ |
| Ïà¶Ôʪ¶È |
20%-95% ÎÞÄý¶ |
| ³ß´ç |
90mmx70mmx20mm (D x W x H) |
| ²Ù×÷ϵͳ |
mips-linux os |
| ÅäÖÃ |
Web server, Telnet, Serial console, Windows based Utility |
| ¶©¹ºÐÅÏ¢ |
SE1302S-TTL£¬
SE1302S (º¬RS232/RS485/RS422 Driver) ²úÆ·ÅäÌ×£ºAtopÈí¼þ°²×°¹âÅÌ£¨º¬SDK£©£¬Óû§Ê¹ÓÃÊÖ²á |
