ÍøÂçÊÓÆµ·þÎñÆ÷
GW231A
TCP/IPÍøÂç½Ó¿Ú£¬Ö±½ÓÒÔÌ«Á¬Íø
RS-232/485´®¿Ú¿ÉÑ¡ÓÉPTZ¿ØÖÆ
H.263¶¯Ì¬Ó°ÏñѹËõ
ʵʱ¶àÈÎÎñ²Ù×÷ϵͳ
ÃÜÂëÊܱ£»¤
Ó°Ïñ·Ö±æÂÊ¿ÉÑ¡ÔñCIF(352X288)£¬QCIF(176X144)£¬SQCIF(128X96)ºÍ2CIF(704X240£¬S/W704X480)
ËÙ¶È:CIFÿÃë1-30ÕÅ£¬4·µÄGW234Aÿ¸öͨµÀËÙÂʿɴï2FPS
¿É×Ô¶¯Õì²âNTSC»òPALѶºÅ
¹æ¸ñ
Ó²¼þ
32 Bits RISC CPU
DRAM: 16M Bytes
FLASH: 2M Bytes ¿ÉÌṩӦÓóÌÐòÏÂÔØ
6M Bytes RAM Ô¤¾¯¼Ç¼
µ¥´®¿Ú RS-232»òRS-485½çÃæ¿ÉÑ¡
ÒÔÌ«ÍøÂç½Ó¿Ú:10BaseT(RJ45)»ò¹âÏË(VF45)
GW231A: Êý×ÖÊäÈë(DI)x1, Êý×ÖÊä³ö(DO)x1
GW234A:Êý×ÖÊäÈë(DI)x4, Êý×ÖÊäÈë(DO)x1
ÍøÂç½çÃæ
10MbpsÒÔÌ«Íø
TCP, UDP, BOOTP, DHCP, PPPoE
Ó°ÏñÊäÈë
GW231A: 1×éÄ£ÄâÊäÈë
GW234A: 4×éÄ£ÄâÊäÈë
×Ô¶¯Õì²âNTSC/ PAL ÐźÅ
NTSC/PALÓÉBNCÁ¬½ÓÆ÷ÊÓÆµÊäÈë
Ó°ÏñѹËõ
GW231A: CIFËٶȿɴï30FPS, 2CIF³¬¹ý10FPSÒÔÉÏ
GW234A: 1CHËٶȿɴï30FPS, 4CHÏÂΪ2FPS/CH.
CIF(352x240), QCIF(176x144),2CIF(704x240, S/W 704x480)
¿Éµ÷ÕûÁÁ¶È, ¶Ô±È¶È, É«¶È, ±¥ºÍ¶ÈºÍ»ÖÊ
NTSC/PALÓÉ BNCÁ¬½ÓÆ÷ÊÓÆµÊä³ö
H.263¶¯Ì¬Ó°ÏñѹËõ¸ñʽ
ÒÆ¶¯Õì²â
ÔÊÐí¶àÈÎÎñÕì²âÉ趨
¿Éµ÷ÕûÁéÃô¶È¼°ÔëÒô¶È
ÎÞÐèÈκÎÍⲿӲ¼þÖ§³Ö
»·¾³
ζÈ: 0 ~ 50ò¾
ʪ¶È: 20 ~ 80%RHG
µçÔ´: 12VDC/1.2A
°²È« ÃÜÂëÊܱ£»¤
³ß´ç 197mm(W), 37mm(H), 116mm(L)
¶©¹ºÐÅÏ¢
(by Model) GW231A-2-TP (US)
Vin x 1, Vout x 1, RS-232, 10 Base-T Ethernet RJ-45 connector.
GW231A-2-TP(EU)
GW231A-5-TP (US)
Vin x 1, Vout x 1, RS-485, 10 Base-T Ethernet RJ-45 connector.
GW231A-5-TP(EU)
