²úÆ·Ãû³Æ£º
PEAK 8920VL2
ÐÍ ºÅ£º
PEAK 8920VL2
CPU Support Support Dual-Core IntelR XeonR processor 5100 series and Quad-Core IntelR XeonR Processor 5300 series (80W) IntelR Embedded Processor List ( IntelR Longevity CPU): Dual-Core IntelR XeonR Processor (5130 & 5140) Dual-Core IntelR XeonR Processor LV (5128¡¢5138¡¢5148) 1066/1333 MHz FSB support Main Memory 4 x 240-pin four channel DDR 2 FB-DIMM Support ECC / Register DDR2 memory up to 8GB Chipset IntelR 5000P memory controller Hub IntelR 6321ESB I/O controller Hub BIOS AMI BIOS Plug & Play support 8M-bit flash ROM Support Soft off¡¢Wake on LAN¡¢Power On by PS2 Keyboard Function Key¡¢RTC alarm Power On Power on after power failure On-board LAN 2 x IntelR 82573L PCI Express Gigabit Ethernet Support Boot From LAN (PXE) Support Wake On LAN (When 5Vsb power available) 2 x RJ45 with LED Display ATI ES1000 PCI graphic Controller 32MB DDR2 SDRAM VGA Memory 1 x DB15 VGA port I/O Interface USB 2.0: 4 ports through I/O bracket USB 2.0: 2 ports¡¢with 1x6 JST (2.5mm ) Serial port: 2 ports¡¢with 2x5 box-header (2.0mm) support RS-232 only Parallel port: 1 port ¡¢with 2x13 box-header (2.0mm)¡¢Bi-directional¡¢EPP/ECP PS/2: 1 x Mini-Din Keyboard/Mouse GPIO: Support 4 sets of general purpose I/O each with TTL level (5V) interface FAN: 2 x 4-pin FAN connectors (for CPU coolers) 1 x on board buzzer 1 x 2-pin power on switch 1 x SMBus 2.0 to Backplane 1 x 2-pin header for reset 1 x 5-pin header for key lock 1 x 2-pin header for power LED 1 x 2-pin header for HDD LED Storage SATA: 2 ports¡¢support RAID 0,1 through Backplane IDE: 1 x 40-pin IDE connector¡¢support Ultra ATA 33/66/100 1 x 2-pin JST (2.5mm) power connector for DOM (Disk On Module) System Monitor 8 voltage (For +3.3V¡¢+5V¡¢Vcore x2¡¢1.8V¡¢1.5V¡¢5Vsb¡¢and Vbattery) 3 temperature (For 2 CPU and system) 3 FAN speed monitor ( 2 for CPU and 1 for ESB2) Watchdog Timer Watchdog Timer is programmable by software from 0 to 255 seconds (Tolerance 10% under room temperature 25¡ãC) On-board RTC On-chip RTC with battery back up 1 x External Li-Lon battery Power Input Power source from backplane through PICMG 1.3 Golden Finger¡¢support ATX mode Dimensions PICMG 1.3 SHB 338.58 mm (L) x 126.39 mm (W) Environment Operating Temperature: 0¡ãC ~ 60¡ãC (for Board Level Only) Storage Temperature: -20730;C to 85730;C Relative Humidity: Operating: 10%~90% (non-condensing) Non-Operating: 5%~95% (non-condensing) Certifications CE approval FCC Class A
