·3 pole AC inlet IEC320-C14 ·Class I power (with earth pin) ·No load input power<2.0W ·Compact size, light weight ·Suitable standby IT machine ·短路/过载/过压 ·Fix switching frequency and regulation ·LED indicate for power on ·Fully enclosed plastic case ·UL/CSA/TUV/FI/D/N/S/CE/FCC ·Made in China for Low cost ·1 年保修 (110×62×30mm)
