²úÆ·Ãû³Æ£º
Èð´«ÍøÂçͨѶƽ̨ÖܱßÅä¼þABN-172
ÐÍ ºÅ£º
ABN-172
- Switch automatically to bypass mode while power fails and software hangs
- Dual 64-bit Gigabit Ethernet ports base on Intel® 82546GB controller
- Supports 133MHz PCI-X bus and backwards compatible with 64/32-bit PCI
- Built-in Watchdog Timer (WDT) to switch Ethernet ports to bypass mode by system hang and power failure
- Easy configuration of Normal/Bypass mode and WDT time-out timing per hardware (DIP-switch) or software programming
- Built-in LED as well as on-board LED pin-header for Ethernet status and bypass mode for optional LED location
- Specifications are subject to change without notice.
- Pentium® 4, Pentium® III, Pentium® II and Celeron® are registered trademarks of Intel® Corporation.
- Xeon8482; is a trademark of Intel® Corporation.
- Other trademarks, logos, brands and company names are the property of their respective owners.
