²úÆ·Ãû³Æ£º
Half-sized PCI SBC
ÐÍ ºÅ£º
ROBO-6710VLA
Èð´«
- Support Intel® low power consumption 400MHz FSB Pentium® M/Celeron® M process for thermal/power limited applications
- Fanless solution with on-board Intel® ULV Celeron® M 600MHz processor (ROBO-6730VLA)
- Support dual display function via VGA and LVDS output
- Perfect engine of slim computer with LVDS interface LCD panel
- On-board Intel® 10 BASE-T/100BASE-TX Fast Ethernet
- One SODIMM socket at the rear that supports up to 1GB system memory
- One Type II Compact Flash at the rear that supports up to 1 GB flash disk for installation OS without hard drive
- Audio Code 97 (AC97) 2.2 for a high quality audio architecture
- PCI bus interface for higher flexibility and expandability
