²úÆ·Ãû³Æ£º
ISA ¹¤ÒµµçÄÔ±³°å PBP-06I
ÐÍ ºÅ£º
PBP-06I
Èð´«
- 4-layer PCB with ground and power planes for reducing noise and keeping lower impedance
- Frame rated PCB at 94-V0
- LED power indicator for +5V,+12V,-5V and 12V
- Heavy duty terminal block connector for industrial power supply wiring(*)
- Equipped with gold-plated socket for good contact
- Easy cut for dual or multi system(*)
- Plug-in sockets of termination resistors for highspeed signal(*)
"*"means for most part of products |
- 175.3(L) x 135(W) mm;6.90"(L) x 5.31"(W)
- Specifications are subject to change without notice.
- All trademarks, logos, brand names and company names are the property of their respective owners.
