产品名称: NX800LX
型  号: NX800LX
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard AMD Geode LX800 @ 0.9 W with 128K L2 Cache or 64K L1 Cache
BIOS
Award 4Mb Flash BIOS
System Chipset
AMD Geode LX800/CS5536
I/O Chip
Winbond W83627HG-AW
System Memory
One 200-pin SODIMM socket supports up to 1 GB DDR 400 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
I/O
MIO
1 x EIDE (DMA 33), 2 x RS-232, 1 x K/B, 1 x Mouse
IrDA
115k bps, IrDA 1.0 compliant
USB
4 x USB 2.0 ports
DIO
8-bit General Purpose I/O for 4 DI and 4 DO
Display
Chipset
AMD Geode LX800 with integrated graphics engine
Display Memory
AMD LX800 integrated graphics controller supports up to 254 MB video memory
Resolution
CRT mode: 1024 x 768 @ 32 bpp (85 Hz)
TFT mode: 1600 x 1200 @ 32 bpp (100Hz)
LVDS
Single channel 18-bit LVDS
Audio
Chipset
AMD Geode CS5536
AC97 Codec
Realtek ALC655 supports 2 CH AC97 Audio
Audio Interface
Mic in, Line in, Line out
Ethernet
LAN 1
Realtek RTL8139DL LAN
Ethernet Interface
100Base-Tx Fast Ethernet compatible: Realtek RTL8139DL
Mechanical & Environmental
Power Requriement
+5 V @ 0.945 A, +12 V @ 0.147 A, +3.3 V @ N/A, (with Geode LX800 500 MHz & 512 MB DDR SO-DIMM)
Power Type
ATX
Operating Temperature
0~60C(32~140F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
4.72" x 4.72" (120mm x 120mm)
Weight
0.88lbs (0.4kg)
Ordering Information
NX800LX
AMD Geode LX800 500 MHz Nano ITX Main Board with VGA, TFT, LVDS, Audio, LAN, CF, Mini PCI,
2 COM, 4 USB 2.0 & GPIO
关 键 词: 主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
