产品名称: ATX BC915GV
型  号: BC915GV
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® µFC-LGA 775 socket Supports Pentium® 4 / Celeron® D with 65nm process technology
FSB
800/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
Intel® 82915GV GMCH/ ICH6
I/O Chip
Winbond W83627EHG-A
System Memory
Four 240-pin DIMM sockets support up to 4 GB Dual Channel DDR2 400/533/667 SDRAM
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, five PCI slots (PCI Rev. 2.2 compliant), 2 ISA slots
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD , 1 x LPT, 2 x RS-232, 1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
Display
Chipset
Intel® 82915GV GMCH integrated Graphics Media Accelerator 900
Display Memory
Intel® DVMT 3.0 supports 128 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (85 Hz)
VGA/LCD Interface
PCI-E X16 for SDVO interface
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
TV-OUT
Through ADD2 TV-out Card (Customized BIOS required)
Audio
Chipset
Intel® ICH6
Azalia Codec
Realtek ALC 888GR, 8 CH High-Definition Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Gigabit LAN
LAN 1
Realtek RTL8110SC PCI Gigabit LAN
LAN 2
Ethernet Interface
1000Base-T Fast Ethernet compatible: Realtek RTL8110SC
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
2 x RJ45 ports
4 x USB ports
Audio I/O (3 jacks)
Internal I/O Connector
2 x USB connector supports additional 4 USB ports
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
1 x Floppy disk drive connector
1 x IDE connector for two devices 1 x COM connector
1 x Chassis intrusion connector
1 x CD audio in connector
4 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF out connector 1 x Power LED connector
1 x System panel connector
1 x CPU Fan connector
2 x Chassis Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 4.26 A, +12 V @ 10.12 A, +3.3 V @ 7.22mA, 5Vsb@987mA (with Intel(R) Pentium(R) D 3.2 GHz & 1 GB DDR2)
Power Type
ATX
Operating Temperature
0~50°C (32~122°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
BC915GV
Intel LGA775 Pentium 4 / Celeron ATX Main Board with VGA, Audio, Dual Gb LAN, 8 USB 2.0, 1, PCI-E X16, 5 PCI, & 2 ISA
关 键 词: 嵌入式 主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
