Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ATX BV945G
²úÆ·Ãû³Æ£º ATX BV945G
ÐÍ ºÅ£º BV945G
Æ· ÅÆ£º BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® µFC-LGA 775 socket Supports Pentium® D / Pentium® 4 / Celeron® D/ Core 2 Duo with 65nm process technology
FSB
1066/800/533 MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82945G GMCH/ ICH7
I/O Chip
Winbond W83627EHG-A
System Memory
Four 240-pin DIMM sockets support up to 4 GB Dual Channel DDR2 533/667 SDRAM
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
SmartFan Control
Speed Cruise Mode
Expansion
One PCI Express X16, one PCI Express X1, five PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD , 1 x LPT, 3x RS-232, 1xRS-232/422/485, 1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
Display
Chipset
Intel® 82945G GMCH integrated Graphics Media Accelerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (85 Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
TV-OUT
Through ADD2 TV-Out Card (Customized BIOS required)
Audio
Chipset
Intel® ICH7
Azalia Codec
Realtek ALC 888, 8 CH High-Definition Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Gigabit LAN
LAN 1
Intel® 82573L Gigabit LAN
LAN 2
Ethernet Interface
1000Base-T Fast Ethernet compatible: Intel® 82573L
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
2 x RJ45 ports
4 x USB ports
Audio I/O (3 jacks)
Internal I/O Connector
1 x 4-pin ATX 12V Power connector
1 x Floppy disk drive connector
1 x IDE connector for two devices
3 x COM connectors
1 x Chassis intrusion connector
1 x CD audio in connector
1 x TPM connector
4 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF out connector 1 x Speaker connector
1 x System panel connector 1 x 3-pin Power LED connector
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 5.14 A, +12 V @ 5.25 A, +3.3 V @ 0.59 A (with Intel® Celeron® D 2.93 GHz & 512 MB DDR SDRAM)
Power Type
ATX
Operating Temperature
0~60&def;C (32~140¡ãF)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
BV945G
: Intel LGA775 Core 2 Duo / Pentium D / Pentium 4 / Celeron D ATX Main Board with VGA, Audio, Dual Gb LAN, 4 COM, 8 USB 2.0, 1 PCI-E X16, 1 PCI-E X1, & 5 PCI
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
