产品名称: ATX AX965Q
型  号: AX965Q
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel&ereg uFC-LGA 775 socket Supports Quad-core Core 2 Extreme / Core 2 Duo / Pentium® D PentiumR 4 / CeleronR D with 65nm process technologyrpo
FSB
1066/800/533 MHz
BIOS
Award 16 Mb Flash ROM BIOS
System Chipset
Intel® 82Q965 GMCH / ICH8DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to
8 GB Dual Channel DDR2 800/667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, five PCI slots
(PCI Rev. 2.2 compliant), 2 ISA
I/O
MIO
1 x UltraDMA 133/100/66/33, 8 x SATA,1 x FDD,
1 x LPT, 4 x RS-232, 1x K/B,1 x Mouse
USB
10 x USB 2.0 port
e-SATA
1 x e-SATA
IEEE-1394A
1 x 1394 (optional)tm
Display
Chipset
Intel® 82Q965 GMCH integrated Graphics
Media Accelerator 3000
Display Memory
Intel® DVMT 4.0 supports 256 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
LVDS
Through ADD2 HDMI Card
(Customized BIOS required)
DVI
Through ADD2 LVDS Card
TV-out
Through ADD2 DVI Card
DTV-out
Through ADD2 TV-out Card
Audio
Chipset
Intel® ICH8DO
AC97 Codec
ADIR AD1988 7.1-channel High Definition
Audio CODEC
Audio Interface
Mic in, Line in, CD Audio in, Line out,
6CH (6 jacks), S/PDIF
Ethernet
LAN 1
Intel® 82566DM Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x External SATA
* 1 x VGA port
* 1 x IEEE1394a connector (optional)
* 1 x RJ45 port
* 4 x USB 2.0/1.1
* 7.1 CH Audio I/O (6 jacks)
Internal I/O Connector
* 3 x USB connectors support
additional 6 USB ports
* 1 x 24-pin ATX Power connector
* 1 x 4-pin ATX 12V Power connector
* 1 x Floppy disk drive connector
* 1 x IDE connector for two devices
* 4 x COM connector
* 1 x CD audio in connector
* 1 x TPM connector
* 7 x SATA connectors
* 1 x Front panel audio connector
* 1 x S/PDIF Out Header
* 1 x System panel connector
* 1 x CPU Fan connector
* 2 x Chassis Fan connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
AX965Q
Intel® LGA775 Quod-core / Core 2 Extreme / Core 2 Duo / Pentium® D Pentium® 4 / Celeron® D ATX Main Board with VGA, Audio, Gb LAN, 10 USB 2.0, 1 PCI-E X16, 1 PCI-E X4, & 5 PCI
关 键 词: 嵌入式 主板 AX965Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
