System |
CPU |
Intel® uFC-LGA 775 socket Supports Core 2 Duo Pentium® D / PentiumR 4 / Celeron® D with 65nm process technology |
FSB |
1066/800/533 MHz |
BIOS |
Award 4 Mb Flash BIOS |
System Chipset |
Intel® 82945G GMCH/ ICH7 |
I/O Chip |
Winbond W83627EHG-A |
System Memory |
Four 240-pin DIMM sockets support up to 4 GB Dual Channel DDR2 667/533 SDRAM |
Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
Expansion |
One PCI Express X16, one PCI Express X1, five PCI slots (PCI Rev. 2.2 compliant) |
I/O |
MIO |
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD, 1 x LPT, 1 x RS-232, 1 x RS-232/422/485, 1x K/B, 1 x Mouse |
USB |
8 x USB 2.0 ports |
Display |
Chipset |
Intel® 82945G GMCH integrated Graphics Media Ac-celerator 950 |
Display Memory |
Intel® DVMT 3.0 supports 224 MB video memory |
Max. 3D Resolution |
2048 x 1536 @ 32 bpp (75 Hz) |
VGA/LCD Interface |
PCI-E X16 VGA interface |
LVDS |
Through ADD2 LVDS Card (Customized BIOS required) |
DVI |
Through ADD2 DVI Card (Customized BIOS required) |
TV-out |
Through ADD2 TV-out Card (Customized BIOS required) |
Audio |
Chipset |
Intel® ICH7 |
AC97 Codec |
Realtek ALC 888, 7.1 CH High-Definition Audio Codec |
Audio Interface |
Mic in, Line in, CD Audio in, Line out, S/PDIF |
Ethernet |
LAN 1 |
Intel® 82573L Gigabit LAN |
Back Panel I/O Port |
* 1 x PS/2 Keyboard * 1 x PS/2 Mouse * 1 x Parallel port * 1 x Serial port * 1 x VGA port * 1 x RJ45 port * 4 x USB ports * Audio I/O (3 jacks) |
Internal I/O Connector |
Internal I/O Port |
* 2 x USB connectors support additional 4 USB ports * 1 x 24-pin ATX Power connector * 1 x 4-pin ATX 12V Power connector * 1 x Floppy disk drive connector * 1 x IDE connector for two devices * 1 x COM connectors * 1 x Chassis intrusion connector * 1 x CD audio in connector * 1 x TPM connector * 4 x SATA connectors * 1 x Front panel audio connector * 1 x S/PDIF out connector * 1 x Speaker connector * 1 x System panel connector * 1 x 3-pin Power LED connector * 1 x CPU Fan connector * 1 x Chassis Fan connector * 1 x Power Fan connector |
Mechanical & Environmental |
Power Requirement |
+5 V @ 4.26 A, +12 V @ 10.12 A, +3.3 V @ 722 mA (with Intel® Core 2 Duo E6400 2.13 GHz & 1 GB*2 DDR2 SDRAM) |
Power Type |
ATX |
Operating Temperature |
0~60¡ãC (32~140¡ãF) |
Operating Humidity |
0%~90% relative humidity, non-condensing |
Size (L x W) |
12" x 9.6" (304.8 mm x 243.84 mm) |
Weight |
1.32 lbs (0.6 Kg) |
