产品名称: Micro ATX RX965Q
型  号: RX965Q
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel uFC-LGA 775 socket Supports Quad-core / Core 2 Extreme/ Core 2 Duo / Pentium D / Pentium 4 / Celeron D with 65nm process technology
FSB
1066 / 800 / 533 MHz
BIOS
Award 16 Mb Flash ROM BIOS
System Chipset
Intel® Q965/ICH8DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 800/667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X1, two PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
1 x UltraDMA 133/100/66/33, 6 x SATA, 1 x FDD , 1 x LPT, 1x RS-232, 1x K/B, 1 x Mouse
USB
10 x USB 2.0 ports
eSATA/IEEE-1394A
1 x e-SATA
Display
Chipset
Intel(R) Graphics Media Accelerator 3000
Display Memory
Max. shared memory of 256MB
Max. 3D Resolution
2048 x 1536 @ 32 bpp(@ 75Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
HDMI
Through ADD2 HDMI Card (Customized BIOS required)
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
TV-out
Through ADD2 TV-Out Card (Customized BIOS required)
Audio
Chipset
Intel® ICH8
AC97 Codec
ADI(R) AD1988A 8-channel High Definition Audio CODEC
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Gigabit Ethernet
LAN 1
Intel® 82566DM PCI-E Gigabit Ethernet Controller
Ethernet Interface
1000Base-T Fast Ethernet compatible: Intel®82566DM
Back Panel I/O Port
I/O Ports
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port 1 x External SATA
1 x VGA port
1 x RJ45 port
4 x USB 2.0/1.1
Audio I/O (6 jacks)
Internal I/O Connector
I/O Connectors
3 x USB connectors support additional 6 USB ports
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
1 x Floppy disk drive connector
1 x IDE connector for two devices
1 x COM connector
1 x Chassis intrusion connector
1 x CD audio in connector
1 x TPM connector
5 x SATA connectors
1 x Front panel audio connector 1 x S/PDIF Out Header
1 x System panel connector
1 x CPU Fan connector
2 x Chassis Fan connector
1 x Power Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 10.37 A, +12 V @ 3.07 A, +3.3 V @ 2.83 A (with Intel Core 2 Duo E6300 1.86GHz & 1 GB DDR2 SDRAMx4)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6" x 9.6" (243.84 mm x 243.84 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
RX965Q
Intel LGA775 Quad-core / Core 2 Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron Micro ATX Main Board with VGA, 8 CH Audio, Gb LAN, 10 USB 2.0, 1 PCI-E X16, 1 PCI-E X4, & 2 PCI
关 键 词: 嵌入式 主板 RX965Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
