产品名称: Micro ATX MX865G
型  号: MX865G
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® uFC-LGA 775 socket Supports Pentium® 4 / Celeron® D with 90nm process technology
FSB
800/533 MHz
BIOS
Award 4Mb Flash ROM BIOS
System Chipset
Intel® 82865G GMCH/ ICH5
I/O Chip
Winbond W83627EHG-A
System Memory
Four 184-pin DIMM sockets support up to 4 GB
Dual Channel DDR 266/333/400 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One AGP 8X, three PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
2 x EIDE (Ultra DMA 100), 2 x SATA,1 x FDD
1 x LPT, 1 x RS-232, 1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
Display
Chipset
Intel® 82865G GMCH integrated Extreme Graphics 2
Display Memory
Intel® DVMT 2.0 supports 64 MB video memory
Max. 3D Resolution
1600 x 1200 @ 32 bpp (75 Hz)
VGA/LCD Interface
AGP 8X VGA interface
LVDS
Through ADD LVDS Card
(Customized BIOS required)
DVI
Through ADD DVI Card
TV-out
Through ADD TV-out Card
Audio
Chipset
Intel® ICH5
AC97 Codec
Realtek ALC655 6-channel AC97 Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN1
Realtek RTL8100C PCI 10/100Mbps LAN
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x Serial port
* 1 x VGA port
* 1 x RJ45 port
* 4 x USB 2.0/1.1
* Audio I/O (3 jacks)
Internal I/O Connector
* 2 x USB connector supports
additional 4 USB 2.0 ports
* 1 x 20-pin ATX Power connector
* 1 x 4-pin ATX 12V Power connector
* 1 x Floppy disk drive connector
* 2 x IDE connector for four devices
* 1 x COM connector
* 1 x Chassis intrusion connector
* 1 x CD audio in connector
* 2 x SATA connectors
* 1 x Front panel audio connector
* 1 x S/PDIF out connector
* 1 x System panel connector
* 1 x CPU Fan connector
* 1 x Chassis Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 0.48 A, +12 V @ 8.36 A, +3.3 V @ 10.42 A (with Intel® Pentium D 2.8 GHz & 512MB*3 + 1GB*1 DDR SDRAM)
Power Type
ATX
Operating Temperature
0~50°C (32~122°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6" x 9.6" (243.84 mm x 243.84 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
MX865G
Intel® LGA775 Core 2 Duo / Pentium®
Intel® LGA775 Pentium® D / Pentium® 4 Celeron® D Micro ATX Motherboard with VGA, Audio, LAN, 8 USB 2.0, 1 AGP 8X, & 3 PCI
关 键 词: 嵌入式 主板 MX865G
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
