Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Mini ITX MX700CXM
²úÆ·Ãû³Æ£º Mini ITX MX700CXM
ÐÍ ºÅ£º MX700CXM
Æ· ÅÆ£º BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
VIA C7 1 GHz onboard
FSB
400/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
VIA CX700/M
I/O Chip
Winbond W83627HG-AW
System Memory
1 x 240-pin DIMM sockets support max. 1 GB DDR2 400/533 memory. Supports EEC for DDR2 400 only
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 133), 1x LPT, 2 x SATA, 4 x RS-232 (COM2 support RS422/485, 1 x K/B, 1 x Mouse
IrDA
115k bps, IrDA 1.0 compliant
USB
6 x USB 2.0 ports
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
Integrated UniChrome Pro 3D/2D Graphics & Video processor
Display Memory
UniChrome Pro 3D/2D Graphics & Video processor supports up to 128 MB video memory
Resolution
1920 * 1200 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS, LVDS, or CRT
LVDS
VIA CX700 supports Single channel 18/24-bit/Dual-channel 36-bit LVDS
Audio
Chipset
VIA CX700
AC97 Codec
Realtek ALC883 supports 5.1 CH Audio
Audio Interface
Mic in, Line in, Line out
Gigabit Ethernet
LAN1
Realtek RTL8100C 10/100 LAN
LAN2
I/O
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
4 x USB 2.0/1.1
2 x RJ45 port
8-Channel Audio I/O ( 3 jacks )
Internal I/O Connector
1 x USB connectors support additional 2 USB ports
1 x 20-pin ATX Power connector
1 x IDE connector for two devices
1 x Floppy disk drive connector / slim
3 x COM connector
1 x CPU Fan connector
1 x Chassis Fan connector
1 x LVDS connector
1 x TV connector
1 x LVDS inv connector
1 x Audio connector
1 x CD_In connector
1 x GPIO
1 x Front panel
Mechanical & Environmental
Power Requriement
+5 V @ 1.745 A, +12 V @ 0.202 A, +3.3 V @ 0.721 A, 5 Vsb @ 0.23 A (with VIA C7 1.0 GH & 512 MB DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0~60C(32~140F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88lbs (0.4kg)
Ordering Information
MX700CXM
VIA C7 1 GHz Mini ITX Main Board with VGA, 2-CH LVDS, 5.1 CH Audio, Dual (Giga) LAN, PCI, & 6 USB 2.0
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
