产品名称: Mini ITX MX700CN2-C10
型  号: MX700CN2-C10
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
VIA C7 1 GHz onboard
FSB
400/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
VIA CN700/VT8237R+
I/O Chip
ITE IT8712F-S
System Memory
1 240-pin DIMM socket supports up to 1 GB DDR2 533
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
S3
S3 Support
I/O
MIO
2 x EIDE (Ultra DMA 133), 1x LPT, 2 x SATA,
1 x K/B, 1 x Mouse, 2 x RS232
USB
6 x USB 2.0 ports
Display
Chipset
Integrated UniChrome Pro 3D/2D Graphics & Video processor
Display Memory
UniChrome Pro 3D/2D Graphics & Video processor supports up to 64 MB video memory
Resolution
1600 x 1200 @ 32 bpp (75 Hz)
Dual Display
CRT + LVDS
LVDS
VIA VT1636 supports Single channel 18/24-bit
Audio
Chipset
VIA VT8237R+
AC97 Codec
Realtek ALC653 supports 5.1 CH Audio
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Ethernet
LAN 1
Realtek RTL8100CL 10/100 LAN
Ethernet Interface
100Base-T Fast Ethernet compatible: Realtek RTL8100CL
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x VGA port
1 x Serial port
4 x USB 2.0/1.1
1 x RJ45 port
Audio I/O (3 jacks)
Internal I/O Connector
1 x USB connectors support additional 2 USB ports
1 x 20-pin ATX Power connector
2 x IDE connector for four devices 1 x COM connector
1 x CD audio in connector
2 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF Out Header
1 x System panel connector
1 x LVDS connector
1 x CPU Fan connector
1 x System Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 2.48 A, +12 V @ 385mA, +3.3 V @ 4.38 A, 5Vbs@460mA (with VIA C7 1.5G & DDRII 533, 512 MB)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
MX700CN2-C10
VIA C7 1 GHz Mini ITX Main Board with VGA, 2-CH LVDS, 5.1 CH Audio, 10/100 LAN, PCI & 6 USB 2.0
关 键 词: 嵌入式 主板 MX700CN2-C10
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
