产品名称: Mini ITX MX852GME 主板
型  号: MX852GME
价  格:
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Supports uFC-PGA 478 Intel Pentium 4/Celeron with FSB 400/533 MHz
FSB
400/533 MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel 82852GME GMCH/82801DB ICH4
I/O Chip
Winbond® W83627HG-AW
System Memory
One 184-pin DIMM socket supports up to 1 GB DDR 266/333 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant),one mini PCI slot
I/O
MIO
2 x EIDE (Ultra DMA 100), 1 x FDD , 1 x LPT, 5 x RS-232, 1 x RS-232/422/485, 1 x K/B, 1 x Mouse
IrDA
115 kbps, IrDA 1.0 compliant
USB
6 x USB 2.0 ports
DIO
8-bit General Purpose I/O for DI and DO
IEEE-1394A
Display
Chipset
Intel® FW82852GME GMCH integrated Extreme Graphics 2 controller
Display Memory
Intel® DVMT 2.1 supports 64 MB video memory
Resolution
CRT mode: 1600 x 1200 @ 32 bpp (85 Hz)
LCD/Simultaneous mode: 1600 x 1200 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS, or DVI/TV-out + LVDS or CRT + DVI
VGA/LCD Interface
LVDS
Intel 852GME supports Single channel 18/24-bit/Dual-channel 36-bit LVDS
DVI
Chrontel CH7009B DVI transmitter up to 135M pixels/second
TV-OUT
Chrontel CH7009B TV encoder supports both NTSC/PAL
Supports both S-video and composite video
Audio
Chipset
Intel® 82801DB ICH4
AC97 Codec
Realtek ALC655 supports 5.1 CH AC97 Audio
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN 1
Realtek RTL8100C 10/100 Mbps LAN
LAN 2
Ethernet Interface
100Base-T Fast Ethernet compatible: Realtek RTL8100C
Mechanical & Environmental
Power Requirement
+5 V @ 1.41 A, +12 V @ 5.19 A, +3.3 V @ 4.84 A, 5Vsb@2.0A (with Intel(R) Pentium(R) 4 2.4GHz & 1GB DDR SDRAM)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 kg)
Ordering Information
MX852GME
Intel Pentium 4 / Celeron ITX Main Board with VGA, 2-CH LVDS, DVI, TV-out, 5.1 CH Audio, Dual LAN, CF, PCI, 6 COM, 6 USB 2.0, & GPIO
关 键 词: 嵌入式 主板 MX852GME
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
