产品名称: Mini ITX MX852GM-C6
型  号: MX852GM-C6
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel Processor 600MHz/512K
FSB
400 MHz
BIOS
Award™ 512 KB Flash BIOS
System Chipset
Intel 82852GM GMCH/82801DB ICH4
I/O Chip
Winbond W83627HF-AW
System Memory
One 184-pin DIMM socket supports up to 1 GB DDR 200/266 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant), one Mini PCI slot
I/O
MIO
2 x EIDE (Ultra DMA 100), 1 x FDD , 1 x LPT, 3 x RS-232, 1 x RS-232/422/485, 1 x K/B, 1 x Mouse
IrDA
115 kbps, IrDA 1.0 compliant
USB
6 x USB 2.0 ports
DIO
16-bit General Purpose I/O for DI and DO
IEEE-1394A
Display
Chipset
Intel 82852GM GMCH integrated Extreme Graphics 2 controller
Display Memory
Intel DVMT 2.1 supports up to 64 MB video memory
Resolution
CRT mode: 1600 x 1200 @ 32 bpp (85 Hz)
LCD/Simultaneous mode: 1600 x 1200 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS, or DVI/TV-out + LVDS or CRT + DVI
LVDS
Intel 8552GM supports Single channel 18/24-bit/Dual-channel 36-bit LVDS
DVI
Chrontel CH7009B DVI transmitter up to 135M pixels/second
TV-out
Chrontel CH7009B TV encoder supports both NTSC/PAL
Supports both S-video and composite video
Built-in Touch Screen (Optional)
Chipset
PenMount DMC9000
Touch Screen Interface
With 9-pin 2 mm box header
(can be selected to support 4/5/8-wire touch screen)
Audio
Chipset
Intel 82801DB ICH4
AC97 Codec
VIA VT1616 supports 5.1 CH AC97 Audio
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN 1
Realtek RTL8110S Gigabit LAN
LAN 2
Ethernet Interface
1000Base-T Fast Ethernet compatible: Realtek RTL8110S
Mechanical & Environmental
Power Requirement
+5 V @ 1.34 A, +12 V @ 0.2 A, +3.3 V @ 4.46 A, 5 Vsb @ 0.18 A (with Intel Celeron M 600 MHz & 1GB DDR SDRAM)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 kg)
Ordering Information
MX852GM-C6
Intel Celerom M 600 MHz Mini ITX Main Board with VGA, 2-CH LVDS, DVI, TV-out, 5.1 CH Audio, Gb LAN, CF, PCI, Mini PCI, 4 COM, 6 USB 2.0, & GPIO
关 键 词: 嵌入式 主板 MX852GM-C6
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
