产品名称: Mini ITX MX945GM2
型  号: MX945GM2
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Supports Intel(R) uFC-PGA 478 Core Duo / Core Solo/Core 2 Duo with 65nm process technology
FSB
533/667 MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel 82945GM GMCH/82801GM ICH7-M
I/O Chip
Winbond W83627HF
System Memory
2x 240-pin DIMM socket supports up to 4GB Dual Channel DDR2 533/667 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, One PCI slot (PCI Rev. 2.2 compliant), One Mini PCI
I/O
MIO
1 x EIDE (Ultra DMA 100), 3x RS232, 1 x RS232/422/485, LPT, 2 x SATA, 1 x 1 x K/B, 1 x Mouse (COM1~2 with Power output)
IrDA
115k bps, IrDA connector (1.0 compliant)
USB
8 x USB 2.0 ports
DIO
8-bit General Purpose I/O for DI and DO (Smbus)
IEEE-1394A
Display
Chipset
Intel 82945GM GMCH integrated Graphics Media Accelerator 950
Display Memory
Intel DVMT 3.0 supports 224 MB video memory
Resolution
2048 x 1536 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS
LVDS
Intel 945GM supports Single channel 18/24-bit/Dual-channel 36-bit/48-bit LVDS
DVI
Through ADD2 DVI Card
TV-out
Supports both S-video and composite video
Built-in Touch Screen
Chipset
Touch Screen Interface
Audio
Chipset
Intel 82801GM ICH7-M
AC97 Codec
ADI AD1986A 6-channel High Definition Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN 1
Marvell 88E8053 PCI-E Gigabit Ethernet Controller
LAN 2
Ethernet Interface
1000Base-Tx Fast Ethernet compatible: Dual Intel 82573L
Mechanical & Environmental
Power Requirement
+5 V @ 1.37A, +12 V @ 1.73 A, +3.3 V @ 3.92 A,5 Vsb @ 0.34A
Power Type
ATX
Operating Temperature
0~60C (32~140F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
MX945GM2: Intel Core Duo / Core Solo/Core 2 Duo Mini ITX Main Board with VGA, 2-CH LVDS, 5.1 CH Audio, Dual Gb LAN, CF, PCI-E x16, PCI, Mini PCI, & 8 USB 2.0
关 键 词: 嵌入式 主板 MX945GM2
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
