产品名称: Mini ITX MX945GM
型  号: MX945GM
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
Systems
CPU
Supports Intel uFC-PGA 478 Core 2 Duo / Core Duo / Core Solo with 65nm process technology
Core Logic Chipsets
Intel(R) Mobile 82945GM GMCH + Intel(R) 82801GM ICH7-
System Memory
One 240-pin DIMM socket support up to 2GB DDR2 533/667 MHz SDRAM
BIOS
Award 512 KB Flash BIOS
Expansion Interface
1 x PCI Express x16 slot (supports ADD2 DVI Card)
1 x PCI Express x 1 slot
1 x PCI 32-bit/33MHz slot
Additional Features
H/W Status Monitor Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats.
I/O
MIO
1 x K/B, 1 x Mouse, 1 x IDE (Ultra DMA 66/100), 1 x LPT
USB
2 x USB 2.0 ports (Rear I/O), 1 x USB pin headers for additional 2 USB
COM
1 x RS232 for COM1 (Rear I/O), 1 x RS232/422/485 for COM2~ COM5
SATA
2 x SATA
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
Intel® 82945GM GMCH Integrated Graphics Media Accelerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Resolution
2048 x 1536 @ 32 bpp (75 Hz)
Dual Display
CRT + LVDS
VGA Interface
1 x DB-15 VGA
LVDS
Single Channel 18-bit/Dual Channel 36-bit LVDS
Audio
AC97 Codec
Realtek ALC888 support 8 Channel HD Audio
Audio Interface
Mic-In, Line-In, Line-Out, SPDIF
Ethernet
LAN 1
Intel® 82573L (1000Base-T Fast Ethernet)
LAN 2
Mechanical and Environment
Power Supply Voltage
+5 V @ 3.34 A, +12 V @ 0.09 A, +3.3 V @ 3.74 A, 5 Vsb @ 0.23 A (with Intel® Pentium® M 1.8 GHz & 256 MB DDR SDRAM)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Form Factor
Mini ITX
Dimensions
6.7" (L) x 6.7" (W)
Weight
0.88 lbs (0.4Kg)
Ordering Information
MX945GM
Intel® 945GM chipset, Socket M, LVDS, VGA, 2 Gbit LAN, 1 PCIe x16, PCIe x1, 1 PCI, 2 SATA, 5 COM, GPIO, 4 USB
关 键 词: 嵌入式 主板 MX945GM
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
