产品名称: Mini ITX IX852GM4-C6
型  号: IX852GM4-C6
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel® Celeron® M 600MHz w/512K L2 Cache
FSB
400MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82852GM GMCH/82801DB ICH4
I/O Chip
Winbond W83627EHG-A
System Memory
One 184-pin DIMM socket supports up to
1 GB DDR 200/266 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling
fan status. Auto throttling control when
CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
supports 3 PCI master
S3
S3 Support
SmartFan Control
Speed Cruise Mode
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x RS-232
USB
6 x USB 2.0
DIO
16-bit General Purpose I/O for DI and DO
Extra SATA Chips
Silicon Image Sil 3512 supports 2 SATA
with 150 MB/s transfer rate
Display
Chipset
Intel® 82852GM GMCH integrated Extreme
Display Memory
Intel® DVMT 2.1 supports up to 64 MB video memory
Resolution
CRT mode: 1600 x 1200 @ 32 bpp (85 Hz)
LCD/Simultaneous mode:
Dual Display
CRT + LVDS, or CRT + DVI
LVDS
Intel® 852GM supports Single channel 18 /
Dual-channel 36-bit LVDS
DVI
Chrontel CH7301 DVI transmitter up to
135M pixels/second
Audio
Chipset
Intel® 82801DB ICH4
Audio Code
Realtek ALC655 supports 5.1 CH Audio ( 3 jacks )
Audio Interface
Mic in, Line in, Line out
Audio Amplifer
TPA3005D2 Stereo 5 Watt per channel
Ethernet
LAN1
Realtek RTL8110SC 1000Base-T Gigabit
Ethernet Controller
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 2 x RS-232
* 1 x VGA port
* 1 x DVI port 4 x USB 2.0/1.1
* 1 x RJ45 Port
* 5.1 CH Audio I/O (3 jacks)
Internal I/O Connector
* 1 x USB connectors support
2 USB ports
* 1 x 20-pin ATX Power connector
* 1 x IDE 40-pin connector for two devices
* 2 x COM port header
* 2 x SATA connectors
* 1 x Front panel audio connector
* 1 x Audio amplifier connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0°~60°C (32°~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX852GM4-C6
Intel® Celeron® Mini ITX Motherboard with
VGA, 2-CH LVDS, Audio, Gb LAN,
4 COM, 6 USB 2.0, 2 SATA, 1 PCI, CF
关 键 词: 嵌入式 主板 IX852GM4-C6
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
