产品名称: Mini ITX IX965GME
型  号: IX965GME
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Supports IntelR socket P Core Duo / Core Solo
Core 2 Duo with 65nm process technology
FSB
533/800 MHz
BIOS
Award 16 MB SPIROM
System Chipset
Intel® GME965/ICH8M-DO
I/O Chip
Winbond W83627DHG-A/1.1
System Memory
Two 200-pin SODIMM sockets support up to 4 GB
Dual Channel DDR2 533/667 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when
CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant) supports
3 PCI master
S3
S3 Support
SmartFan Control
Speed Cruise Mode
I/O
MIO
1 x DVI-D/D-Sub, 1 x Gigabit LAN, 4 x USB 2.0,
4 x RS232, 1 x K/B, 1 x Mouse, Audio (Mic, Line in/out)
IrDA
115k bps, IrDA 1.0 compliant
USB
10 x USB 2.0
DIO
8-bit General Purpose I/O for DI and DO
Display
Chipset
Intel® GME965 integrated Graphics Media
Accelerator X3100
Display Memory
Intel® DVMT 4.0 supports 384 MB video memory
Resolution
2048 x 1536 @ 32 bpp(@ 60Hz)
Dual Display
CRT + LVDS, or CRT + DVI-D
LVDS
Dual-channel 24-bit LVDS
DVI
Chrontel CH7307C DVI transmitter up to
165M pixels/second
Audio
Chipset
Intel® ICH8M-DO
Audio Code
ADI 1882 5.1-CH HD Audio Codec
Audio Interface
Mic in, Line in, (CD Audio in), Line out
Audio Amplifer
TPA3005D2 Stereo 5 Watt per channel
Ethernet
LAN 1
Realtek RTL8111B PCI-E 1000Base-T Gigabit
Ethernet Controller
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 2 x RS-232
* 1 x VGA port
* 1 x DVI port
* 4 x USB 2.0/1.1
* 1 x RJ45 Port (one existed, another option)
* 5.1-CH Audio I/O (3 Jacks)
Internal I/O Connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX965GME
Intel® Core Duo / Core Solo / Core 2 Duo Mini ITX Motherboard with DVI/VGA,
LVDS, Amplified Audio, Giga LAN,
4 COM, 10 USB 2.0, 3 SATA,
8-bit GPIO & 1 PCI
关 键 词: 嵌入式 主板 IX965GME
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
