产品名称: Mini ITX IX965Q
型  号: IX965Q
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Support Intel® LGA 775 Core Duo / Core 2 Duo Pen-tium® 4 / Celeron® D processor with 65 nm processor technology
FSB
533/800/1066 MHZ
BIOS
Award 8MB
System Chipset
Intel® Q965/ICH8
I/O Chip
Winbond W83627DHG-A
System Memory
Two 240-pin sockets up to 4GB Dual Channel
DDR2 533/667/800 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
Watchdog Timer
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when
CPU overheats
Expansion
One PCI Express x16
S3
S3 Support
SmartFan Control
Speed Cruise Mode
I/O
MIO
1 x D-Sub, Gigabit LAN, 6 x USB 2.0, 2 x SATA,
2 x RS232, 2 x PS/2 (KB and MS), Audio
USB
6 x USB2.0
Display
Chipset
Intel® 82Q965 GMCH integrated Graphics
Media Accelerator 30000
Display Memory
Intel® DVMT 4.0 supports 256 MB video memory
Resolution
2048 x 1536 @ 32 bpp(@ 75Hz)
Dual Display
CRT
Audio
Chipset
Intel® ICH8
AC97 Codec/Audio Code
ADI 1882 5.1+2-CH HD Audio Codec
Audio Interface
Mic in, Line in, Line out
Audio Amplifer
TPA3005D2 Stereo 5 Watt per channel
Ethernet
LAN 1
Realtek RTL8111B PCI-E 1000Base-T Gigabit
Ethernet Controller
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 2 x RS-23
* 1 x VGA port
* 4 x USB 2.0/1.1
* 1 x RJ45 Port
* 5.1 CH Audio I/O (3 Jacks)
Internal I/O Connector
* 1 x 20-pin ATX Power connector
* 2 x SATA connectors
* 1 x Front panel audio connector
* 1 x Audio amplifier connector
* 1 x System panel connect
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX965Q
Intel® Core Duo / Core Solo / Core 2 Duo Mini ITX Motherboard with VGA, Amplified Audio, GigaLAN, 2 COM, 6 USB 2.0, 2 SATA, 1 PCI Ex16, TPM
关 键 词: 嵌入式 主板 IX965Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
