Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Mini ITX MX800LX
²úÆ·Ãû³Æ£º Mini ITX MX800LX
ÐÍ ºÅ£º MX800LX
Æ· ÅÆ£º BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard AMD Geode LX800 @ 0.9 W with 128K
L2 Cache or 64K L1 Cache
BIOS
Award 4 Mb KB Flash BIOS
System Chipset
AMD Geode LX800/CS5536
I/O Chip
Winbond W83627HG-AW
System Memory
One 184-pin DIMM socket supports up to 1 GB
DDR 400 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling
fan status. Auto throttling control when
CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant), One Mini PCI
S3
S3 Support
I/O
MIO
1 x EIDE (Ultra DMA 66), 1 x FDD, 1 x LPT,
4 x RS-232, 1 x K/B, 1 x Mouse, COM1 with power
IrDA
115k bps, IrDA 1.0 compliant
USB
4 x USB 2.0 ports
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
AMD Geode LX800 with integrated graphics engine
Display Memory
AMD LX800 integrated graphics controller
supports up to 32 MB video memory
Resolution
CRT mode: 1920 x 1440 @ 32 bpp (85 Hz)
TFT mode: 1600 x 1200 @ 32 bpp (100Hz)
LVDS
AMD Geode LX800 supports Single channel
18/24-bit/Dual-channel 36-bit LVDS
Built-in Touch Screen (Optional)
Chipset
PenMount DMC9000
Touch Screen Interface
With 9-pin 2 mm box header (can be selected to support 4/5/8-wire touch screen)
Audio
Chipset
AMD Geode CS5536
Audio Codec
Realtek ALC203 supports 2 CH AC97 Audio
Audio Interface
Mic in, Line in, CD audio in, Line out
Ethernet
LAN 1
Realtek RTL8100C 10/100Mbp LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x Serial port
* 1 x VGA port
* 2 x RJ45 port
* 4 x USB 2.0/1.1
* Audio I/O ( 3 jacks )
Internal I/O Connector
* 1 x USB connectors
* 1 x 20-pin ATX Power connector
* 1 x Floppy disk drive connector
* 1 x IDE connector for two devices
* 3 x COM connector
* 1 x CPU Fan connector
* 1 x Chassis Fan connector
* 1 x CD audio in connector
* 1 x LVDS connector
* 1 x LVDS panel backlight connector
* 1 x IR connector
* 1 x TFT connector
* 1 x GPIO connector
* 1 x Front panel
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60¡ãC (32~140¡ãF)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
MX800LX
AMD Geode LX800 500 MHz Mini ITX
Motherboard with VGA, TFT, LVDS, Audio, Dual LAN, CF, PCI, Mini PCI, 4 COM, 4 USB 2.0, & GPIO
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
