16-Bit, 250 kS/s, 80 Analog Inputs Multifunction DAQ Two 16-bit analog outputs (833 kS/s) 24 digital I/O; two 32-bit counters; digital triggering Correlated DIO (8 clocked lines, 1 MHz) Includes NI-DAQmx, VI Logger Lite data-logging software, and other measurement services NIST-traceable calibration and more than 70 signal conditioning options Select high-speed M Series for 5x faster sampling rates or high-accuracy M Series for 4x resolution The National Instruments PCI-6225 is a low-cost multifunction M Series data acquisition (DAQ) board optimized for cost-sensitive applications. The board offers 80 analog inputs, two analog outputs, 24 digital I/O lines, and two counter/timers. The NI PCI-6225 is ideal for applications including data logging, control, and sensor and high-voltage measurements when used in conjunction with NI signal conditioning. Synchronize the operations of multiple boards using the RTSI bus.
Low-cost M Series devices incorporate advanced features such as the NI-STC 2 system controller, NI-PGIA 2 programmable amplifier, and NI-MCal calibration technology to increase performance and accuracy. Also consider the high-speed M Series devices for 5X faster sampling rates or the high-accuracy M Series devices for 4X resolution and superior measurement accuracy.
Cables and Accessories The PCI-6225 requires two cables and accessories to use all I/O. For optimal performance, NI recommends using the SHC68-68-EPM extended performance, shielded cable for connector 0 and the SHC68-68 basic, shielded cable for connector 1. For ease-of-use and convenience, the PCI-6225 will ship with cable identification labels to help with distinguishing the SHC68-68-EPM from the SHC68-68. Jump-start your application development by learning the seven steps to design, set up, and test your data acquisition system with the ¡°Data Acquisition: 7 Steps to Success Tutorial Kit¡±.
Calibration and Warranty Services All M Series devices have a 3-year manufacturing warranty. Additional warranty and calibration services may be purchased at the same time as purchasing the device. Choose from extended warranty, lifetime warranty, or lifetime warranty with one basic calibration service. Refer to Hardware Services linked below for more information.
Driver Software M Series devices work with multiple OSs, with three driver software options including NI-DAQmx, NI-DAQmx Base, and the Measurement Hardware DDK. To learn more about driver software or to download a driver, click on the ¡°Download NI drivers¡± link below. M Series devices are not compatible with the Traditional NI-DAQ (Legacy) driver.
Application Development Environments M Series devices are compatible with the following versions (or later) of NI application software LabVIEW 7.x, LabWindows/CVI 7.x, or Measurement Studio 7.x;SignalExpress 1.x; VI Logger 2.0; or LabVIEW with the LabVIEW Real-Time Module 7.1. M Series devices are also compatible with Visual Studio .NET, Visual Basic 6, and C/C++/C#. For additional information on supported application development environments, please refer to the Read Me documentation associated with the driver software.
