免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → XTend™ OEM 无线射频模块
产品名称: XTend™ OEM 无线射频模块
型 号:
价 格: 0.00
品 牌: digi
List Price: $179 each
Volume Discounts Available
  Digis XTend OEM RF modules provide unprecedented range in a low-cost wireless data solution. The modules are easy-to-use, require minimal power and provide reliable delivery of critical data between devices. Their small form factor saves valuable board space.
  Due to innovations stamped in its design, the XTend module supplies two- to eight-times the range of other modules operating within the unlicensed 900 MHz frequency band. The range gained by OEMs and integrators is due to proprietary technologies embedded into each module such as superior RX (receiver) sensitivity, interference immunity, modulation/demodulations techniques, and others.
  No configuration is necessary for out-of-box RF communications. The module’s default configuration supports a wide range of data system applications. Advanced configurations can be implemented using simple AT or binary commands.
Product summary:
  • ISM 900 MHz operating frequency
  • 1 mW - 1 Watt power output (up to 40 mile range)
  • 256-bit AES Encryption
  • Several advanced networking options and topologies supported
  • Approved for use in the United States, Canada, and Australia (XTH9)
  • Available with DigiMesh™
公司名称: Digi International(香港)有限公司
电 话: 021 51506898 / 刘浩传
手机:
地 址: 上海市徐汇区零陵路899号飞洲国际广场26L
邮 编: 200030
主 页: http://www.digi.com.cn
  • MiniCore™ RCM5700 体积紧凑的经济型核心模块
  • RCM5400W RabbitCore核心模块
  • Rabbit 5000 微处理器
  • RCM2200 RabbitCore核心模块
  • RCM2100 RabbitCore核心模块
  • RCM2000 RabbitCore核心模块
  • Rabbit 4000微处理器
  • Rabbit 3000 TFBGA 微处理器
  • Rabbit 3000 微处理器
  • Rabbit 2000 微处理器
