Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Modbus¹âModem(WEED)
²úÆ·Ãû³Æ£º Modbus¹âModem(WEED)
ÐÍ ºÅ£º 2C29
¹úWeed Instrument¹«Ë¾´´½¨ÓÚ1968Äê,×ܲ¿Î»ÓÚÃÀ¹úµÂ¿ËÈøË¹ÖݰÂ˹͡ÊÐ,ÓµÓÐ5000ƽ·½Ó¢³ßµÄÏÖ´ú»¯³§·¿.ÊǾø»Ê¢ÃûµÄ¹¤Òµ×Ô¶¯»¯²úÆ·ÖÆÔìÉÌ,Ϊ°üÀ¨º½¿Õº½Ìì¼°ºË¹¤ÒµÔÚÄÚµÄÖØÒª²úÒµÌṩ¸ßÆ·ÖʵÄPLCÒÔ¼°¹¤Òµ×ÜÏßÓ¦ÓùâÏËModem,Ä£Äâ»òÊý×ÖÁ¿¹âÏËÊÕ·¢Æ÷,¹¤ÒµÒÔÌ«Íø½»»»»úºÍ¹âµçת»»Æ÷µÈ.
2C29+2E07+2A10 ¹âÏËModem/24VDC PSM,ST850nm¶àÄ£,1M,DIN35mm /Ö§³ÖЭÒé:Modicon Modbus plus.
SPECIFICATIONS Mechanical: Mounting: 35mm DIN Rail Weight: < 9 oz ( 250g ) Baud Rate: 1.0M Baud Copper Cable Connector: Standard ModBus Plus Connector (DB-9F) (Compatible w/Schneider P/N AS-MBKT-085 or AS-MBKT-185) Maximum Devices and Copper Cable Length Supported per Module: 32 Devices, 1500 feet Cable End Termination: External, 120 Ohm, user supplied at both ends of any wire cable segment Power Indicator: Green LED Communications Activity Indicator: Amber LED Ambient Conditions: -40¡ãC to 85¡ãC Operational 0 to 95% Relative Humidity Non-Condensing
¡¤ Í걸µÄ°²¹æÈÏÖ¤
CE Marked Class I, Division 2, Groups A, B, C, D UL RecognizedComponentPower Supply
ÉîÛÚÊÐѶ¼Ç¿Æ¼¼ÓÐÏÞ¹«Ë¾:WWW.COAMRK.CN/רҵ¡¢·þÎñ¡¢Áé»îµÄÐÂÒ»´úÁìÏȹ¤ÒµÍ¨Ñ¶ÍøÂç½â¾ö·½°¸¹©Ó¦ÉÌ¡£
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐѶ¼Ç¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 13066988513 / Áõ²¨
ÊÖ»ú£º 13066988513
µØ Ö·£º ÉîÛÚÄÏÉ½Çø´´ÒµÂ·ÖÐÐ˹¤Òµ³Ç2¶°413
ÓÊ ±à£º 518054
Ö÷ Ò³£º http://www.comark.cn/
  • CANת¹âÏË(Ïû·À±¨¾¯×ÜÏß)
  • DPÖÐ¼ÌÆ÷(HUB)
  • ControlNet¹âModem(Weed)
  • ¹¤ÒµÒÔÌ«Íø¹âÏËÊÕ·¢Æ÷
  • ControlNetÂÞ¿ËΤ¶û(AB)1786-RPA,1786-RPFS
  • Ѷ¼ÇControlNet×ÜÏßÊý¾Ý¹â¶Ë»ú
  • CANË«ÍøÈßÓà¹âÏË»·
  • DeviceNet×ÜÏßÊý¾Ý¹â¶Ë»ú
  • Modbus¹âModem(WEED)
  • Modbus×ÜÏßÊý¾Ý¹â¶Ë»ú
