²úÆ·Ãû³Æ£º
ÎÞ·çÉÈǶÈëʽµçÄÔ
ÐÍ ºÅ£º
FEBC-3510
Introduction
FEBC-3510ÊÇÒ»¿î½ô´ÕÐ͵ÄǶÈëʽ¿ØÖÆPC¡£¸Ã²úÆ·¾ß±¸Ç¿´óµÄÔËËãÄÜÁ¦£¬ÎÞ·çÉȵ͹¦ºÄ¹¤×÷£¬ÔËÐпɿ¿Îȶ¨£¬¾ßÓÐÁ¼ºÃµÄÀ©Õ¹ÐÔÄܺÍÁé»îµÄI/OÅäÖ᣼á¹Ì½ô´ÕµÄ÷¢ÖåÉè¼ÆÂÁÖýÏäÉíºÍ¼ò½ÝÀο¿µÄÄÚ²¿¼Ü½Ó£¬²»µ«Óп¹³å»÷¿¹Õñ¶¯±£»¤£¬¾ßÓзÀ³¾¡¢¿¹¸ßκÍÄ͵ÍεÄÌØÐÔ£¬¶øÇÒÓÐÉ¢ÈÈ×÷Ó㬱£³ÖϵͳÕý³£ÔËÐеÄζȡ£
Specifications
- CPU£ºIntel® ULV Celeron® M 600MHz / 1.5GHz ´¦ÀíÆ÷
- ϵͳÄڴ棺DDR SDRAM DIMM¡Á1£¬×î´ó1GB£¨¿ÉÑ¡£©
- VGA/¼üÅÌ/Êó±ê£ºDB-15 VGA ½Ó¿Ú£¬PS/2¼üÅÌ&Êó±ê
- ÒÔÌ«Íø£º10/100Base-TX RJ-45½Ó¿Ú¡Á1
- SSD£ºÁùºÏÒ»¶Á¿¨Æ÷£¨CF¿¨£¬SD¿¨£¬MMC¿¨£¬MS£¨PRO£©¿¨ºÍÖÇÄÜSM¿¨£©£¬Type ¢ò CompactFlash™²å²Û¡Á1
- Çý¶¯´ÅÅ̼ܣº
¿ÉÑ¡2.5"HDD+³¬±¡CD-ROM¼Ü×° ¿ÉÑ¡3.5"HDD¼Ü×°
- ´®¿Ú£ºRS-232¡Á1£¬RS-232/422/485¡Á1
- USB£ºUSB 2.0¶Ë¿Ú¡Á3
- ÒôƵ£ºMic-in/Line-in/Line-out£¬Ê¹ÓÃÀ©Õ¹Ïß
- DVI£ºDVI out½Ó¿Ú¡Á1
- TV-out£ºS¶Ë×ÓÊÓÆµÊäÈëÐźšÁ1£¬RCA¡Á1
- ÎÞÏßÍø¿Ú£ºÎÞÏßÍø¿¨¹¤¾ß°ü£¨802.11b/g£©£¨¿ÉÑ¡£©
- IEEE 1394: IEEE 1394½Ó¿Úx1£¨¿ÉÑ¡£©
- ϵͳ¿ØÖÆ£ºµçÔ´¿ª¹Ø¡Á1£¬ÖØÆô°´Å¥¡Á1
- LEDָʾµÆ£ºµçԴָʾµÆ¡Á1£¬HDDָʾµÆ¡Á1
- ¼àÊÓ¶¨Ê±Æ÷£º¿É±à³Ì³¬Ê±Öжϻòϵͳ¸´Î»
- Power supply£º
ACÍâÖÃ(105W AC-DC ÊÊÅäÆ÷)£º Êä³ö¶î¶¨¹¦ÂÊ£º105W ÊäÈëµçѹ£º100VAC ~ 240VAC @ 50 ~ 60Hz Êä³öµçѹ£º15V@7A DCÄÚÖ㺠ÊäÈëµçѹ£ºDC 9V ~30V (5A ~ 1.5A)£¬´ø3-pin·ï»ËÍ·
- ²Ù×÷ϵͳ£ºWindows® CE.NET 5.0£¬Windows® XP Embedded£¬Windows® XP£¬Windows® 2000
- ¹¹Ô죺ÂÁ¼·ÐÍÍâ¿Ç£¬÷¢ÖåÉ¢ÈÈÉè¼Æ
- ÑÕÉ«£ºÒø°×+Ä«ºÚ
- °²×°·½Ê½£º±Ú¹Ò°²×°£¬µ¼¹ì°²×°£¬Ì¨Ê½°²×°
- ¾»ÖØ£º2.53kg
- ×ÜÖØ£º4.7kg
- ¹¤×÷ζȣº
-20¡æ¡«70¡æ¡ª¡ªCeleron® M 600MHz, (CFD) -20¡æ¡«60¡æ¡ª¡ªCeleron® M 600MHz, (HDD) -20¡æ¡«60¡æ¡ª¡ªCeleron® M 1.5GHz, (CFD) -20¡æ¡«55¡æ¡ª¡ªCeleron® M 1.5GHz, (HDD)
- ¹¤×÷ʪ¶È£º5¡«95%@40¡æ£¬ÎÞÀäÄý
- Õñ¶¯£º
5g rms/5¡«500Hz/Ëæ»ú£¬ÔËÐÐ״̬£¨CFD£© 1g/5¡«500Hz/Ëæ»ú£¬ÔËÐÐ״̬£¨HDD£©
- ³å»÷£º
100g·åÖµ¼ÓËÙ¶È(³ÖÐøÊ±¼ä11ms)(CFD) 15g·åÖµ¼ÓËÙ¶È(³ÖÐøÊ±¼ä11ms)(HDD)
- EMC£ºCE
Ordering Information
- FEBC-3510-CM600-S001
ÎÞ·çÉÈÏäÌå¿ØÖÆPC, Intel® Celeron® M 600MHz´¦ÀíÆ÷,DC 9-30VµçÔ´,Audio,TV-OUT,DVI,ATX·½Ê½,³¬±¡¹âÇý
- FEBC-3510-CM600-E001
- FEBC-3510-CM1.5-S001
ÎÞ·çÉÈÏäÌå¿ØÖÆPC, Intel® Celeron® M 1.5GMHz´¦ÀíÆ÷,DC 9-30VµçÔ´,Audio,TV-OUT,DVI,ATX·½Ê½,³¬±¡¹âÇý
- FEBC-3510-CM1.5-E002
