Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÎÞ·çÉÈǶÈëʽPC
²úÆ·Ãû³Æ£º ÎÞ·çÉÈǶÈëʽPC
ÐÍ ºÅ£º FEBC-5210
Introduction
FEBC-5210ÊÇÒ»¿î½ô´ÕÐ͵ÄǶÈëʽ¿ØÖÆPC¡£¸Ã²úÆ·¾ß±¸Ç¿´óµÄÔËËãÄÜÁ¦£¬ÎÞ·çÉÈÂÁ¼·Íâ¿ÇÉ¢Èȹ¤×÷£¬ÔËÐпɿ¿Îȶ¨£¬¾ßÓÐÁ¼ºÃµÄÀ©Õ¹ÐÔÄÜ£¨PCIx3£©ºÍÁé»îµÄI/OÅäÖ᣼á¹Ì½ô´ÕµÄ÷¢ÖåÉè¼ÆÂÁÖýÏäÉíºÍ¼ò½ÝÀο¿µÄÄÚ²¿¼Ü½Ó£¬²»µ«Óп¹³å»÷¿¹Õñ¶¯±£»¤£¬¾ßÓзÀ³¾¡¢¿¹¸ßκÍÄ͵ÍεÄÌØÐÔ£¬¶øÇÒÓÐÉ¢ÈÈ×÷Ó㬱£³ÖϵͳÕý³£ÔËÐеÄζȡ£Áí2.5¡¯Ó²ÅÌ×÷·ÀÕðÉè¼Æ£¬ÊʺÏÔÚ¸ü¹ã·ºµÄ³¡ºÏÉÏÓ¦Óá£
Specifications
  • CPU£º Intel Pentium®  M 1.1-1.8G
  • ϵͳÄڴ棺DDR SDRAM 200-pin DIMM¡Á2£¬×î´ó1£Ø2GB
  • VGA/¼üÅÌ/Êó±ê£ºDB-15 VGA ½Ó¿Ú£¬PS/2¼üÅÌ&Êó±ê
  • ÒÔÌ«Íø£º10/100Base-TX RJ-45½Ó¿Ú¡Á1
  • PCI£º 3XPCI 2.1À©Õ¹²å²Û
  • SSD£º ÄÚÖÃType ¢ò Compact Flash™²å²Û¡Á1
  • Çý¶¯´ÅÅ̼ܣº
    Ò»¸ö2.5"HDD·ÀÕðÉè¼Æ°²×°¼Ü£¬¿É½ÓSATA»òIDE½Ó¿ÚÓ²ÅÌ
  • ´®¿Ú£ºRS-232¡Á1£¬RS-232/422/485¡Á1
  • USB£ºUSB 2.0¶Ë¿Ú¡Á4
  • ÒôƵ£ºMic-in/Line-in/Line-out
  • DVI£ºDVI out½Ó¿Ú¡Á1 »ò  LVDS£º¿É½ÓË«6bitºÍË«8bit LCDÆÁ
  • ϵͳ¿ØÖÆ£ºµçÔ´¿ª¹Ø¡Á1
  • LEDָʾµÆ£ºµçԴָʾµÆ¡Á1£¬HDDָʾµÆ¡Á1
  • ¼àÊÓ¶¨Ê±Æ÷£º¿É±à³Ì³¬Ê±Öжϻòϵͳ¸´Î»
  • Power supply£º
    ACÍâÖÃ(105W AC-DC ÊÊÅäÆ÷)£º
        Êä³ö¶î¶¨¹¦ÂÊ£º105W
        ÊäÈëµçѹ£º100VAC ~ 240VAC @ 50 ~ 60Hz
        Êä³öµçѹ£º15V@7A
    DCÄÚÖãº
        ÊäÈëµçѹ£ºDC 9V ~30V (8A ~ 2.5A)
  • ²Ù×÷ϵͳ£ºWindows® CE.NET 5.0£¬Windows® XP Embedded£¬Windows® XP£¬Windows® 2000
  • ¹¹Ô죺ÂÁ¼·ÐÍÍâ¿Ç£¬÷¢ÖåÉ¢ÈÈÉè¼Æ
  • ÑÕÉ«£ºÒø°×+Ä«ºÚ
  • °²×°·½Ê½£º±Ú¹Ò°²×°£¬Ì¨Ê½°²×°
  • ¾»ÖØ£º5.8kg
  • ×ÜÖØ£º6.7kg
  • ¹¤×÷ζȣº
    -10¡æ¡«60¡æ¡ª¡ªPentium M 1.5Hz, (CFD)
    -15¡æ¡«50¡æ¡ª¡ªPentium M 1.5GHz, (HDD)
  • ¹¤×÷ʪ¶È£º5¡«95%@40¡æ£¬ÎÞÀäÄý
  • Õñ¶¯£º
    5g rms/5¡«500Hz/Ëæ»ú£¬ÔËÐÐ״̬£¨CFD£©
    1g/5¡«500Hz/Ëæ»ú£¬ÔËÐÐ״̬£¨HDD£©
  • ³å»÷£º
    100g·åÖµ¼ÓËÙ¶È(³ÖÐøÊ±¼ä11ms)(CFD)
    15g·åÖµ¼ÓËÙ¶È(³ÖÐøÊ±¼ä11ms)(HDD)
  • EMC£ºCE
Ordering Information
l          FEBC-5210-CM600-S001
ÎÞ·çÉÈÏäÌå¿ØÖÆPC, Intel® Celeron® M 600MHz´¦ÀíÆ÷,DC 9-30VÄÚµçÔ´,LAN,Audio,DVI,ATX·½Ê½
l         FEBC-5210-CM1.5-S001
ÎÞ·çÉÈÏäÌå¿ØÖÆPC, Intel® Celeron® M 1.5GMHz´¦ÀíÆ÷,DC 9-30VÄÚµçÔ´, LAN,Audio,DVI,ATX·½Ê½
l         FEBC-5210-S001
ÎÞ·çÉÈÏäÌå¿ØÖÆPC, Intel® Pentium®  M  Dothan Socket479 CPU 1.1GHz UP TO 1.8GHz,DC 9-30VÄÚµçÔ´, LAN,Audio,DVI,ATX·½Ê½
¹«Ë¾Ãû³Æ£º ÉîÛÚÊм¯ºÍ³Ï¿Æ¼¼¿ª·¢ÓÐÏÞ¹«Ë¾
µç »°£º 0755 86021176 / ÚÈÊçÀ¼
ÊÖ»ú£º 13632677821
µØ Ö·£º ÉîÛÚÊÐÄÏÉ½ÇøÉ³ºÓÎ÷·²è¹â¹¤ÒµÇø12¶°7Â¥
ÓÊ ±à£º 518055
Ö÷ Ò³£º http://www.jhctech.com.cn
  • ÎÞ·çÉÈǶÈëʽÏä×öµçÄÔ
  • ECI-4P
  • ECP-200A
  • ECI-120Aת½Ó¿¨
  • ת½Ó°å
  • OFD-65XµçÔ´°å
  • OFD-95XÖ±Á÷µçÔ´°å
  • CPU°ë³¤¿¨
  • ¹¤ÒµÄ¸°å
  • CPU°ë³¤¿¨
