| ϵͳ |
| Processor |
Intel Core Duo/Core 2 Duo/Core Solo Processor;Intel 945GME with ICH7-M DH |
| Chipset |
Intel 945GME GMCH/ICH7-M DH Chipset 667MHz FSB |
| DRAM |
Two types: Onboard or SO-DIMM Onboard - DDR2 512MB/1GB(Option) SO-DIMM - 1 x 200-pin SODIMM sockets, Double Data Rate 2,(DDR2) up to 2 GB,DDR2 400/533/667 MHz |
| BIOS |
AWARD™ 4 Mbit Flash BIOS |
| Watchdog |
256 levels timer interval, from 0 to 255 sec or min setup by software, jumperless selection,generates system reset |
| Power Consumption |
+12 V, +5 VSB |
| Dimension |
125 x 95 mm (4.92" x 3.74") |
| I/O ½çÃæ |
| PATA |
1 x EIDE (UDMA 100) |
| SATA |
2 x SATA, data transfer rates up to 1.5 Gb/s (150MB/s) |
| USB |
8 x USB 2.0 compliant ports |
| Audio |
High definition audio interface(AC97/Azalia) |
| LAN |
Support boot from LAN (PXE) |
| ÏÔʾ |
| CRT Display Mode |
Supports max DAC frequency up to 400 MHz RAMDAC (Three 8-bit DACs) support, DDC2B compliant and up to 2048 x 1536 modes up port |
| LCD Display Mode |
Supports 25 to 112 MHz single/dual channel 18 bit LVDS interface.Maximum panel size supported up to UXGA TFT panel type |
| »·¾³ |
| Operating Temp. |
0 ~ 60 C (32 ~ 140 F) |
| Storage Temp. |
-40 C to 85 C |
| Humidity |
0% to 90%(Non-condensing) |
