| 系统 |
| CPU Support |
Intel Pentium M Processor 478 uFC-PGA,
Intel Celeron M Processor 478 uFC-PGA |
| Chipset |
INTEL 82855GME 400MHz FSB, Integrated Graphics |
| DRAM |
DDR-SODIMM 333MHz ECC up to 1GB |
| BIOS |
Award BIOS |
| Watchdog |
125 miliseconds to 256 sec. |
| Power Consumption |
18W @ 5V(1.1GHz CPU) typical |
| Dimension |
95mm x 114mm ( 3.75" x 4.5" ) |
| I/O 界面 |
| IDE Interface |
Two EIDE interfaces,Ultra ATA /100 |
| LPC interface |
Low Pin Count(LPC) interface support |
| Serial Port |
2 xTTL , IrDA , Parallel Port , FDD |
| Expansion Interface |
ETX Interface |
| LAN |
INTEL82562EM(10/100Mbps) |
| Audio |
AC 97 Link for Audio and Telephony CODECs |
| USB |
4 USB 2.0 OHCI ports |
| 显示 |
| Graphics |
82855GME GMCH internal VGA controller providing 2048x 1536x 8bit/60Hz resolution,max,shared memory 64MB |
| LCD Interface |
Dual Channel 24-bit LVDS via Chrontel CH7305, UXGA 1600x 1200, TV-out(PAL,NTSC),DVI via chrontel CH7009 |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
