| 系统 |
| CPU Support |
Intel Pentium 4 / Celeron (Precott) processor |
| CPU Frequency |
1.4~3.06GHz |
| Chipset |
Intel 845GV + ICH4 (FSB : 400/533MHz) |
| DRAM |
2 x 184-pin DDR DIMM, support DDR333 SDRAM up to 2GB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
16 level Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support ATX power |
| Power Requirement |
+5V, +12V, +3.3V, 5VSB |
| Power Consumption |
+5V : 1.78A / +12V : 5.31A / +3.3V : 0.25A (Pentium 4 2.8GHz) |
| Dimension |
305mm x 244mm (12" x 9.61") |
| I/O 界面 |
| IDE Interface |
2 x 40-pin IDE (UDMA 33/66/100) |
| FDD Interface |
1 |
| Bus Interface |
1 x ISA slot, 6 x PCI slots, 1 x PPCI slot |
| Serial Port |
4 x COM ports, COM1/3/4 for RS232, COM2 for RS232/422/485 |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector |
| Mouse |
LAN |
LAN 1 : Intel 82562ET (10/100Mbps) |
Audio |
AC 97 Codec, Realtek ALC202A with Line-in / Line-out / MIC |
| USB |
6 x USB2.0 |
| 显示 |
| Graphics |
Built-in Intel 845GV, share system memory |
| LCD Interface |
18/36-bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
