| ϵͳ |
| CPU Support |
Intel Celeron D,Pentium 4,Pentium D,Core 2 Duo processor |
| Chipset |
Intel Q965 + ICH8DO + FWH |
| DRAM |
4 x 240-pin DDR2 DIMM,support DDR2 800 SDRAM up to 4GB |
| BIOS |
PhoenixAward PnP BIOS Memory size 8 Mbytes |
| Watchdog |
Built-in from Super I/O |
| Power Supply |
Support ATX Power |
| Power Requirement |
+5V, +12V, +3.3V, -12V, +5VSB |
| Power Consumption |
+5V : 3.2A / +12V : 10.45A / +3.3V : 5.32A / -12V : 0.06A / +5VSB : 0.52A (Pentium 4 3.4GHz) |
| Dimension |
305mm x 244mm (12" x 9.61") |
| I/O ½çÃæ |
| IDE Interface |
One FDD connector with 34-pin Boxheader on board |
| SATA Interface |
Six ports S-ATA connector¡¡ |
| Function BUS |
1 x PCI-E 16X ; 1 x PCI-E 4X ; 4 x PCI ; 1 x ISA |
| Serial Port |
COM1/3/4 for RS-232, COM2 for RS-232/422/485 (COM 3/4 can output +5V or +12V, and use Jumper settings) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP)¡¡ |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector |
| Mouse |
| LAN |
Lan 1:Intel 82573V (10/100/1000Mbps) Lan 2:Intel 82573V (10/100/1000Mbps) Supports Wake-on-LAN |
| Audio |
HD Codec, Reatel ALC262, with Mic / Line-out / Line-in |
| USB |
10 ports, support USB 2.0¡¡ |
| ÏÔʾ |
| Graphics |
Built-in Intel Q965, share system memory, Support CRT, PCI-E 16X (SDVO) |
| »·¾³ |
| Operating Temp. |
0 ~ 60ªÏ C ( 32 ~ 140ªÏ F) |
| Storage Temp. |
-40 ~ 85ªÏ C ( -40 ~ 185ªÏ F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
