| ϵͳ |
| CPU Support |
VIA Mark Processor |
| CPU Frequency |
533/800 MHz |
| Chipset |
Mark + VT82C686B |
| DRAM |
1 x 144-pin SO- DIMM, support PC100/133 SDRAM up to 512MB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
16 level Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT/ATX power¡¡ |
| Power Requirement |
+5V, +12V |
| Power Consumption |
+5VSB : 0.78A / +5V : 3.32A / +12V : 1.52A (VIA Mark 533MHz) |
| Dimension |
102mm x 145mm ( 4.02" x 5.71" ) |
| I/O ½çÃæ |
| IDE Interface |
1 x 44-pin IDE ( UDMA 33/66/100 ) |
| CF |
1 x compact flash slot (IDE)¡¡ |
| FDD Interface |
1 |
| Bus Interface |
PC/104 |
| Serial Port |
2 x COM ports, COM1 for RS232, COM2 for RS232/422/485 ( for 16550 compatible type of UART) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR )¡¡ |
| Keyboard |
Mini DIN connector or external connector |
| Mouse |
Mini DIN connector (selectable w/KB) ¡¡ |
| LAN |
Realtek RTL8139D (10/100Mbps) Support Wake-on-LAN wtih ATX power |
| Audio |
AC 97 Codec, VIA VT1612A With Line-in / Line-out / MIC¡¡ |
| USB |
4 x USB1.1¡¡¡¡ |
| ÏÔʾ |
| Graphics |
Built-in VIA 8606, shared system memory, Support CRT, LVDS & TV-out |
| LCD Interface |
18 /36 - bit LVDS |
| »·¾³ |
| Operating Temp. |
0 ~ 60ªÏ C ( 32 ~ 140ªÏ F) |
| Storage Temp. |
-40 ~ 85ªÏ C ( -40 ~ 185ªÏ F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
