产品介绍: |
| 17“Industrial Fanless Touch Panel Computer |
| Intel Celeron M 1GHz up to Pentium M 1.8GHz CPU |
| 17" SXGA (1280x1024) color TFT LCD |
| Sealed resistive touch screen |
| Support panel / VESA 75 mount |
| DC 11~28V wide-range power input |
| 显示规格 |
| 显示 |
17"SXGA TFT LCD |
| 亮度 |
300 cd/m2 |
| 视角 |
140 / 130 (H/V) |
| 分辨率 |
1280 x 1024 |
| 背光 |
50,000 hrs |
| 系统与结构 |
| 架构 |
Aluminum alloy front panel and metal housing |
| 前面板颜色 |
黑色 |
| CPU |
Intel Celeron M 1GHz / 1.5GHz up to Pentium M 1.8GHz |
| DRAM |
1 x SO-DIMM socket, support DDR 200/266 up to 1GB |
| 存储 |
Space for 2.5" HDD and 1 CF card slot, or 1 Compact Flash card slot |
| 电源 |
DC 11~28V |
| 触摸屏 |
Analog resistive |
2 x COM ports (COM1:RS-232, COM2:RS-232/422/485), 2xUSB 2.0 PS/2 1xkeyboard ,1xmouse, 1 x LAN port (10/100Mbps) ,1 x Audio Line-in, Line-out, speaker, 1 x Parallel port, optional: COM3,VGA |
| 尺寸 |
439(W)x348(H)x86(D)mm |
| Environment Specifications |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 - 90% @50 ℃, 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10 to 25Hz (X,Y,Z direction 2G, 30 minutes) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A | |
| Order No |
Description |
| AHM-6175 |
17" Fanless Industrial Touch Panel Computer w/Resistive Touch Screen | | |
