| 系统 |
| CPU Support |
VIA MARK Processor |
| Chipset |
Mark + VT82C686B |
| DRAM |
1 x 144-pin SO-DIMM, support PC100/133 SDRAM up to 512MB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
16 level Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT/ATX power |
| Power Requirement |
+5V, +12V |
| Power Consumption |
+5V : 2.74A / +12V : 0.065A (VIA Mark 533MHz) +5V : 2.81A / +12V : 0.121A (VIA Mark 800MHz) |
| Dimension |
185mm x 122mm ( 7.28" x 4.8" ) |
| I/O 界面 |
| IDE Interface |
1 x 40-pin IDE ( UDMA 33/66/100 ) |
| SSD |
32-pin socket supports DOC up to 288MB |
| FDD Interface |
1 |
| Bus Interface |
PC/104 |
| Serial Port |
2 x COM ports, COM1 for RS232, COM2 for RS232/422/485 (for 16550 compatible type of UART) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector or external connector |
| Mouse |
Mini DIN connector ( selectable w/KB ) or Y-cable |
| LAN |
Realtek RTL8139D (10/100 Mbps) Support Wake-on-LAN wtih ATX power |
| Audio |
AC 97 Codec, Realtek ALC202A With Line-in / Line-ou t/ MIC |
| USB |
2 x USB 1.1 |
| 显示 |
| Graphics |
Built-in VIA Mark, share system memory, Support CRT, TTL & LVDS |
| LCD Interface |
18/24-bit TTL, 18/36-bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
